[mapguide-users] Berkeley DB Configuration File
Rock Beans rockbeans at gmail.com
Mon Jun 9 16:23:38 EDT 2008
Have you had the need to change the time out settings yourself or do you
know of anyone that has done it? Any info on this topic would be great.
The Rock
On Mon, Jun 9, 2008 at 12:12 PM, Steve Dang <steve.dang at autodesk.com> wrote:
>  MG does not expose any BDB configuration settings in the severconfig.ini
> file. And yes, the DB_CONFIG file may be used to overwrite the default
> values of these settings.
> Steve.
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Rock Beans
> *Sent:* Monday, June 09, 2008 10:26 AM
> *To:* MapGuide Users Mail List
> *Subject:* [mapguide-users] Berkeley DB Configuration File
> Has anyone done anything with timeout settings using a Berkeley DB
> configuration file? Is there a better way to increase timeout settings? I
> did not see anything in the serverconfig.ini file.
>  I've never tried this, but Berkeley DB can support a configuration file:
> http://www.oracle.com/technology/documentation/berkeley-db/db/ref/env/db_config.html
> http://www.oracle.com/technology/documentation/berkeley-db/db/api_c/env_list.html
> It's possible that maybe one of the default parameters could be increased.
> The Rock
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080609/1ce50693/attachment.html
