[mapguide-users] In addition: about the url parameters in fusion
foolfish xjimmyshcn at sohu.com
Tue Jun 10 00:47:07 EDT 2008
In addition,
in traditional method(not use fusion) ,the page in Task Pane would receive 1
Form parameters:
,that's SESSION, request method:
String sessionId = Request.Form.Get("SESSION");
in fusion, there is 3 default URL parameters:
 LOCALE,SESSION and MAPNAME. request method:
    String locale= Request.QueryString.Get("LOCALE").Split(',')[0];
    String sessionId = Request.QueryString.Get("SESSION").Split(',')[0];
    String mapName = Request.QueryString.Get("MAPNAME").Split(',')[0];
foolfish wrote:
> 1)install mapguide studio 2009, then you can create flexible weblayout.
> it's for fusion.
>  note: you can't use base layer in map.
> 2)the map.open(map_name) might occrue error. the map_name is not the same
> as traditional method(not use fusion),suppose the map name is asiamap , in
> fusion it looks like asiamap_fusion4845627ed9705.
> 3)the parent.parent.mapFrame might occrue error. but you can use
> parent.document.getElementById('Map').
> 4)parent.parent.mapFrame.Refresh() cann't be used, you can use
> window.top.Fusion.getWidgetById('Map').drawMap()  to refresh map.
> 5)if you want to select feature,you should do:
> at server, after selection.ToXml() ,you should add the follow line:
>               selection.Save(resService, map_name);
> at client, use   window.top.Fusion.getWidgetById('Map').drawMap()   to
> refresh the map.
> max_samart wrote:
>> Hi All,
>>           I am trying to migrate my application onto fusion(MGOS2.0.1)
>> although  i managed to add maps and other basic functions ,overview map
>> etc but i like to add my different customized search code into the fusion
>> task pane which use to perform search and then return results in the same
>> task pane and when i click on zoom icon, it use to select the feature and
>> returns the info of the feature (Its working in the MGOS2.0.1 but i don't
>> know how to get going into the Fusion-I tried adding the task in the task
>> pane same as MapGuide Open Source and gave the path for the query file
>> but it use to show file not found error).
>> Thks
>> Max !!
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Running-Search-query-from-Task-Pane-in-Fusion-tp17730192p17747706.html
