[mapguide-users] Berkeley DB Configuration File
Steve Dang
steve.dang at autodesk.com
Tue Jun 10 14:38:08 EDT 2008
Just in case someone would like to know ...
Here is an example of how the content of a DB_CONFIG file would look like:
set_lock_timeout 10
set_txn_timeout 10
Where each of the above lines has the format NAME VALUE. One or more whitespace characters are used to delimit the two parts of the line, and trailing whitespace characters are discarded.
You may have a DB_CONFIG file (with the same or different content) at one or more locations of your repositories, e.g.:
..\Repositories\Library\
..\Repositories\Site\
..\Repositories\Session\
Please note that the timeouts are in microseconds and the default values are 0.
Steve.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Steve Dang
Sent: Monday, June 09, 2008 8:06 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Berkeley DB Configuration File
No, I haven't and don't. Some information on how to overwrite the lock and/or transaction timeouts:
http://www.oracle.com/technology/documentation/berkeley-db/db/api_c/env_set_timeout.html
Steve.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rock Beans
Sent: Monday, June 09, 2008 2:24 PM
Subject: Re: [mapguide-users] Berkeley DB Configuration File
Have you had the need to change the time out settings yourself or do you know of anyone that has done it? Any info on this topic would be great.
The Rock
On Mon, Jun 9, 2008 at 12:12 PM, Steve Dang <steve.dang at autodesk.com<mailto:steve.dang at autodesk.com>> wrote:
MG does not expose any BDB configuration settings in the severconfig.ini file. And yes, the DB_CONFIG file may be used to overwrite the default values of these settings.
Steve.
From: mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org>] On Behalf Of Rock Beans
Sent: Monday, June 09, 2008 10:26 AM
Subject: [mapguide-users] Berkeley DB Configuration File
Has anyone done anything with timeout settings using a Berkeley DB configuration file? Is there a better way to increase timeout settings? I did not see anything in the serverconfig.ini file.
I've never tried this, but Berkeley DB can support a configuration file:
http://www.oracle.com/technology/documentation/berkeley-db/db/ref/env/db_config.html
http://www.oracle.com/technology/documentation/berkeley-db/db/api_c/env_list.html
It's possible that maybe one of the default parameters could be increased.
The Rock
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080610/7be63dc7/attachment.html
