[mapguide-users] Berkeley DB Configuration File
Rock Beans rockbeans at gmail.com
Wed Jun 11 13:47:37 EDT 2008
Thank you!
On Tue, Jun 10, 2008 at 1:38 PM, Steve Dang <steve.dang at autodesk.com> wrote:
>  Just in case someone would like to know …
> Here is an example of how the content of a DB_CONFIG file would look like:
> set_lock_timeout         10
> set_txn_timeout          10
> Where each of the above lines has the format *NAME VALUE*. One or more
> whitespace characters are used to delimit the two parts of the line, and
> trailing whitespace characters are discarded.
> You may have a DB_CONFIG file (with the same or different content) at one
> or more locations of your repositories, e.g.:
> ..\Repositories\Library\
> ..\Repositories\Site\
> ..\Repositories\Session\
> Please note that the timeouts are in microseconds and the default values
> are 0.
> Steve.
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Steve Dang
> *Sent:* Monday, June 09, 2008 8:06 PM
> *To:* MapGuide Users Mail List
> *Subject:* RE: [mapguide-users] Berkeley DB Configuration File
> No, I haven't and don't. Some information on how to overwrite the lock
> and/or transaction timeouts:
> http://www.oracle.com/technology/documentation/berkeley-db/db/api_c/env_set_timeout.html
> Steve.
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Rock Beans
> *Sent:* Monday, June 09, 2008 2:24 PM
> *Subject:* Re: [mapguide-users] Berkeley DB Configuration File
> Have you had the need to change the time out settings yourself or do you
> know of anyone that has done it? Any info on this topic would be great.
> The Rock
>  On Mon, Jun 9, 2008 at 12:12 PM, Steve Dang <steve.dang at autodesk.com>
> wrote:
> MG does not expose any BDB configuration settings in the severconfig.ini
> file. And yes, the DB_CONFIG file may be used to overwrite the default
> values of these settings.
> Steve.
> *Sent:* Monday, June 09, 2008 10:26 AM
> *Subject:* [mapguide-users] Berkeley DB Configuration File
> Has anyone done anything with timeout settings using a Berkeley DB
> configuration file? Is there a better way to increase timeout settings? I
> did not see anything in the serverconfig.ini file.
> I've never tried this, but Berkeley DB can support a configuration file:
> http://www.oracle.com/technology/documentation/berkeley-db/db/ref/env/db_config.html
> http://www.oracle.com/technology/documentation/berkeley-db/db/api_c/env_list.html
> It's possible that maybe one of the default parameters could be increased.
> The Rock
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080611/75a1f3bd/attachment.html
