[ZS2] Re: [mapguide-users] Displaying multiple feature selections
in the properties pane
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Jun 10 15:01:19 EDT 2008
http://mapguide.osgeo.org/2.0/documentation.html
The last item is "Fusion Learning Materials for MapGuide".
It should get you started.
Regards, Kenneth Skovhede, GEOGRAF A/S
srie skrev:
> Hi Paul
> I try to create the same thing here using fusion-tech-preview-demo and I
> still can't get it right. Is there any fusion API documentation?or any
> source that I can refer?especially to understand how fusion works
> Thanks & Regards,
> Srie
> Jackie is correct, you would need to add a custom panel ... or you
> could use Fusion (http://demo01.dmsolutions.ca/mapguide/fusion/demo),
> which will be available in MapGuide this fall.
> Cheers
> Paul
> On 5-Sep-07, at 8:20 PM, Jackie Ng wrote:
>> To my knowledge the property pane can only display information for one
>> selected feature, you will probably have to create a custom
>> property pane.
>> - Jackie
>> Simon-43 wrote:
>>> Hi,
>>> I'm looking to find out whether it is possible to return multiple
>>> features into the properties pane within the ajax viewer. I'm
>>> currently
>>> just working through the samples and the documentation, and have
>>> scanned
