[mapguide-users] Displaying multiple feature selections in the properties pane
srie ryne_79 at yahoo.com
Tue Jun 10 14:00:52 EDT 2008
Hi Paul
I try to create the same thing here using fusion-tech-preview-demo and I
still can't get it right. Is there any fusion API documentation?or any
source that I can refer?especially to understand how fusion works
Thanks & Regards,
Srie
Jackie is correct, you would need to add a custom panel ... or you
could use Fusion (http://demo01.dmsolutions.ca/mapguide/fusion/demo),
which will be available in MapGuide this fall.
Cheers
Paul
On 5-Sep-07, at 8:20 PM, Jackie Ng wrote:
> To my knowledge the property pane can only display information for one
> selected feature, you will probably have to create a custom
> property pane.
> - Jackie
> Simon-43 wrote:
>> Hi,
>> I'm looking to find out whether it is possible to return multiple
>> features into the properties pane within the ajax viewer. I'm
>> currently
>> just working through the samples and the documentation, and have
>> scanned
View this message in context: http://www.nabble.com/Displaying-multiple-feature-selections-in-the-properties-pane-tp12512871p17761263.html
