[mapguide-users] Help, 404 erro with MG2 and .net URGENT
Gary Morin gary.morin at keynetix.com
Tue Jun 10 11:35:48 EDT 2008
Hi
I have managed to fix it. It seems that because the .net framework was
installed after IIS, the apsx extension had been prohibited in iis. I just
never spotted it, by making it active it worked, I will now hang my head
in shame.
Thanks
Gary
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: 10 June 2008 16:30
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Help, 404 erro with MG2 and .net URGENT
There are MANY reasons IIS will throw a 404, and most situations never
make it to the log.
The simplest test, is to create a "test.html" file in the folder and try
to view it through IIS.
If that works, try renaming it to "test.aspx" and see what happens.
If the first does not work, you might have security problems.
If the first works but the second doesn't, you might have to enable .Net
in the "Extensions" node of IIS (beware that you need v. 2.0).
Another situation where the first works, but the second doesn't is that
the folder does not allow running scripts.
A variation is that the .Net engine is not registered as a script engine.
If both work but the sample does not, the installer probably missed the
default document for the folder.
Regards, Kenneth Skovhede, GEOGRAF A/S
Gary Morin skrev:
Hi
I'm currently on site and am having problems getting MapGuide 2.0 working.
The config is Windows 2003 an IIS 6 using .net
When I try to view a page I get an 404 error, i.e. the same type of
problem reported before when the application has used the short Dos 8.3
name.
I have also seen the same problem when IIS is installed after framework 2,
the solution here is simple repair framework 2. I have tried this fixes
but I still have the same problem. I can't see anything obviously wrong.
Thanks
Gary
  _____
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080610/2e7d4ad9/attachment.html
