[mapguide-users] ecw on mgos-2.0.1
nclayton
nclayton at gmail.com
Wed Jun 11 11:56:30 EDT 2008
When creating your raster data connections, use "/" instead of "\" in your
paths.
C:/Program
Files/MapGuideOpenSource2.0/WebServerExtensions/www/mapcatalogue/data/world.ecw
instead of
C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapcatalogue\data/world.ecw
it may also be a problem with the space in "Program Files". You may need to
place your ecw files in a different location that does not have spaces i the
path.
hope ths helps
ary sucaya wrote:
> Hello group,
> Did someone succesfully open ecw file on mgos 2.0.1? I went through
> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#Documentation but i couldn't
> get it work. i turn on rasters debugging and here is the result:
> ECW: NCScbmOpenFileView(C:\Program
> Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapcatalogue\data/world.ecw):
> eErr = 0
> ECW: FileInfo: SizeXY=4320,2160 Bands=3
> OriginXY=-180,90 CellIncrementXY=0.0833333,-0.0833333
> ECW: projection=GEODETIC, datum=WGS84
> GDAL: GDALOpen(C:\Program
> succeeds as ECW.
> GDAL: GDALClose(C:\Program
> I tried to change the coordinate system into LL84 (LL84) or LL84-WP
> (LL84-WP) but still unlucky.. Someone know how to solve this?
> Regards,
> Ary Sucaya
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/ecw-on-mgos-2.0.1-tp17778662p17781203.html
