[mapguide-users] ecw on mgos-2.0.1
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Jun 11 13:52:59 EDT 2008
MGOS does not support re-projection of rasters.
Your rasters must be in the same projection as the map.
If they are not, but the coordinate systems are compatible, you can add
a coordinate system override on the feature source.
Beware that MapGuide Studio uses the Mentor projection library and MGOS
uses PROJ.4.
Regards, Kenneth Skovhede, GEOGRAF A/S
ary sucaya skrev:
> I think it is a problem of coordinate system. I can preview my layer
> but i can't see it in map. I tried to create a new map and add the ecw
> layer, mapguide studio automatically add EPSG:4326 (WGS 84) for the
> coordinate system which is not in the list. In this case, i can add
> another layer and able to preview the map.
> ----- Original Message ----
> From: ary sucaya <ary.sucaya at yahoo.com>
> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> Sent: Wednesday, June 11, 2008 6:45:44 PM
> Subject: Re: [mapguide-users] ecw on mgos-2.0.1
> Something peculiar happen here. Previously i can open my ecw file, but
> after a few minutes i revisited back my page, the raster has gone.
> Now, i can't even get a new connection work.
> Sent: Wednesday, June 11, 2008 6:23:30 PM
> Thanks for your reply. That's help me to solve my problem.
> Regards,
> Ary Sucaya
> From: nclayton <nclayton at gmail.com>
> To: mapguide-users at lists.osgeo.org
> Sent: Wednesday, June 11, 2008 5:56:30 PM
> When creating your raster data connections, use "/" instead of "\" in your
> paths.
> C:/Program
> Files/MapGuideOpenSource2.0/WebServerExtensions/www/mapcatalogue/data/world.ecw
> instead of
> C:\Program
> Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapcatalogue\data/world.ecw
> it may also be a problem with the space in "Program Files". You may
> need to
> place your ecw files in a different location that does not have spaces
> i the
> path.
> hope ths helps
> ary sucaya wrote:
> > Hello group,
> > Did someone succesfully open ecw file on mgos 2.0.1? I went through
> > http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#Documentation but
> <http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#Documentation%A0but> i
> couldn't
> > get it work. i turn on rasters debugging and here is the result:
> > ECW: NCScbmOpenFileView(C:\Program
> Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapcatalogue\data/world.ecw):
> > eErr = 0
> > ECW: FileInfo: SizeXY=4320,2160 Bands=3
> > OriginXY=-180,90 CellIncrementXY=0.0833333,-0.0833333
> > ECW: projection=GEODETIC, datum=WGS84
> > GDAL: GDALOpen(C:\Program
> > succeeds as ECW.
> > GDAL: GDALClose(C:\Program
> > I tried to change the coordinate system into LL84 (LL84) or LL84-WP
> > (LL84-WP) but still unlucky.. Someone know how to solve this?
> > Regards,
> > Ary Sucaya
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/ecw-on-mgos-2.0.1-tp17778662p17781203.html
> Sent from the MapGuide Users mailing list archive at Nabble.com
> <http://nabble.com/>.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080611/43d7152f/attachment.html
