[mapguide-users] fusion bug with InvokeURL?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Jun 11 17:51:59 EDT 2008
Works perfectly!! Thanks so much, Paul...
Andrew
Paul Spencer wrote:
> Hi Andrew,
> this problem stems from the fact that we don't pass the selection xml
> around from client to server all the time - I decided that the
> selection can be saved on the server just fine and restored at a later
> time.
> I did find a reasonably simple way to work around this before but I
> can't find the code.  But it did involve a server-side change in the
> code that is being called by InvokeURL, essentially you need to check
> if the value of Select literally equals $CurrentSelection and instead
> of doing something like:
> $selection = new MgSelection($map, $selectionXml);
> you would do
> $selection = new MgSelection($map);
> $selection->Open($resourceService, $mapName);
> (sorry, this in php)
> Please let us know if you attempt this and if it works - then I can
> put it in the wiki
> Cheers
> Paul
> On 11-Jun-08, at 1:34 PM, Andrew DeMerchant wrote:
>> I've been trying to migrate (or look into migrating) my projects to
>> Fusion. They all use an InvokeURL script to pass selected data to
>> another URL. The problem I'm having with this in fusion seems to be
>> totally Fusion's fault. It seems that Fusion's InvokeURL widget is
>> defective. My very first parameter is supposed to be
>> $CurrentSelection - which is supposed to give me an xml selection
>> string. In fusion, all that it does is return a
>> string...."$CurrentSelection". Quite useless....My first parameter in
>> my InvokeURL widget is: Key = Selected, Value =
>> $CurrentSelect....this should give me something like
>> "myurl.asp?Select=xmlblah". Instead, I get
>> "myurl.asp?Select=$CurrentSelection". Is there a known workaround for
>> this?
>> Andrew
>> <logo.gif>
>> Andrew DeMerchant
>> Computer Technologist
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> GEMTEC Limited
>> 191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
	*Andrew DeMerchant*
*Computer Technologist*
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
