[mapguide-users] fusion bug with InvokeURL?
Paul Spencer
pagameba at gmail.com
Wed Jun 11 17:29:44 EDT 2008
Hi Andrew,
this problem stems from the fact that we don't pass the selection xml
around from client to server all the time - I decided that the
selection can be saved on the server just fine and restored at a later
time.
I did find a reasonably simple way to work around this before but I
can't find the code. But it did involve a server-side change in the
code that is being called by InvokeURL, essentially you need to check
if the value of Select literally equals $CurrentSelection and instead
of doing something like:
$selection = new MgSelection($map, $selectionXml);
you would do
$selection = new MgSelection($map);
$selection->Open($resourceService, $mapName);
(sorry, this in php)
Please let us know if you attempt this and if it works - then I can
put it in the wiki
Cheers
Paul
On 11-Jun-08, at 1:34 PM, Andrew DeMerchant wrote:
> I've been trying to migrate (or look into migrating) my projects to
> Fusion. They all use an InvokeURL script to pass selected data to
> another URL. The problem I'm having with this in fusion seems to be
> totally Fusion's fault. It seems that Fusion's InvokeURL widget is
> defective. My very first parameter is supposed to be
> $CurrentSelection - which is supposed to give me an xml selection
> string. In fusion, all that it does is return a
> string...."$CurrentSelection". Quite useless....My first parameter
> in my InvokeURL widget is: Key = Selected, Value =
> $CurrentSelect....this should give me something like "myurl.asp?
> Select=xmlblah". Instead, I get "myurl.asp?Select=
> $CurrentSelection". Is there a known workaround for this?
> Andrew
> <logo.gif>
> Andrew DeMerchant
> Computer Technologist
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> GEMTEC Limited
> 191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
