[mapguide-users] image tile indexes from Maestro?
    Andrew DeMerchant
    andrew.demerchant at gemtec.ca
    Thu Jun 12 09:14:33 EDT 2008
Ah. Easy....thanks! Now when I did that, of course, my coords system
overrides got messed up and I can't seem to fix them from Maestro (or
anywhere, so far) - In Maestro, all I get in my coord category list is
Arbitrary X-Y....If I just paste in the correct string, it'll take it -
but every time I refresh my overrides, it adds a Default in XY-MT. If I
look at the configuration document using Studio, I see that it's got
some coord system stuff in it (in <fdo:WKT>), and that it's wrong (it's
using XY-MT). I'm guessing this is the problem, but have no idea how to
fix it. Here's that section in the configuration doc:
     <gml:baseCRS>
      <fdo:WKTCRS gml:id="Default">
        <gml:srsName>Default</gml:srsName>
<fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
      </fdo:WKTCRS>
    </gml:baseCRS>
    <gml:definedByConversion
xlink:href="http://fdo.osgeo.org/coord_conversions#identity" />
    <gml:derivedCRSType
codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType>
    <gml:usesCS xlink:href="http://fdo.osgeo.org/cs#default_cartesian" />
  </gml:DerivedCRS>
Andrew
Kenneth Skovhede, GEOGRAF A/S wrote:
> Create a new GDal raster (or open an existing).
> In the "Type" field select "Composite".
> Now add files and folders in the list below.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Andrew DeMerchant skrev:
>> The Gdalnotes wiki says:
>> "With the release of FDOGDAL 3.2.3, Frank has added support for tile
>> indexes in an XML config file.
>> MapGuide Maestro <http://trac.osgeo.org/mapguide/wiki/maestro> will
>> allow you to create these tile indexes in an intuitive GUI."
>> Where do I find that gui?
>> Andrew
>> 	*Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
