[mapguide-users] image tile indexes from Maestro?
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Jun 12 09:26:11 EDT 2008
I think you are having a problem with MapGuide's coordinate system:
http://trac.osgeo.org/mapguide/ticket/582
Regards, Kenneth Skovhede, GEOGRAF A/S
Andrew DeMerchant skrev:
> Ah. Easy....thanks! Now when I did that, of course, my coords system
> overrides got messed up and I can't seem to fix them from Maestro (or
> anywhere, so far) - In Maestro, all I get in my coord category list is
> Arbitrary X-Y....If I just paste in the correct string, it'll take it
> - but every time I refresh my overrides, it adds a Default in XY-MT.
> If I look at the configuration document using Studio, I see that it's
> got some coord system stuff in it (in <fdo:WKT>), and that it's wrong
> (it's using XY-MT). I'm guessing this is the problem, but have no idea
> how to fix it. Here's that section in the configuration doc:
> <gml:baseCRS>
> <fdo:WKTCRS gml:id="Default">
> <gml:srsName>Default</gml:srsName>
> <fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
> </fdo:WKTCRS>
> </gml:baseCRS>
> <gml:definedByConversion
> xlink:href="http://fdo.osgeo.org/coord_conversions#identity" />
> <gml:derivedCRSType
> codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType>
> <gml:usesCS xlink:href="http://fdo.osgeo.org/cs#default_cartesian" />
> </gml:DerivedCRS>
> Andrew
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Create a new GDal raster (or open an existing).
>> In the "Type" field select "Composite".
>> Now add files and folders in the list below.
>>> The Gdalnotes wiki says:
>>> "With the release of FDOGDAL 3.2.3, Frank has added support for tile
>>> indexes in an XML config file.
>>> MapGuide Maestro <http://trac.osgeo.org/mapguide/wiki/maestro> will
>>> allow you to create these tile indexes in an intuitive GUI."
>>> Where do I find that gui?
>>> Andrew
>>> *Andrew DeMerchant*
>>> *Computer Technologist*
>>> ph.1-877-2GEMTEC x.163
>>> fax 506-453-9470
>>> /GEMTEC Limited <http://www.gemtec.ca>
>>> /191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
Skipped content of type multipart/related
