[mapguide-users] image tile indexes from Maestro?
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Jun 12 09:48:04 EDT 2008
Odd, since it's been working fine all along....I'm going to try
reinstalling Maestro. As for my image layer - I've managed to get it to
show up now, but it's totally crazy. If I do a layer preview in Studio,
I see a single image - should be about 6....and it's scale is messed up,
because I have to zoom way way out to see it.
Andrew
Kenneth Skovhede, GEOGRAF A/S wrote:
> I think you are having a problem with MapGuide's coordinate system:
> http://trac.osgeo.org/mapguide/ticket/582
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Andrew DeMerchant skrev:
>> Ah. Easy....thanks! Now when I did that, of course, my coords system
>> overrides got messed up and I can't seem to fix them from Maestro (or
>> anywhere, so far) - In Maestro, all I get in my coord category list
>> is Arbitrary X-Y....If I just paste in the correct string, it'll take
>> it - but every time I refresh my overrides, it adds a Default in
>> XY-MT. If I look at the configuration document using Studio, I see
>> that it's got some coord system stuff in it (in <fdo:WKT>), and that
>> it's wrong (it's using XY-MT). I'm guessing this is the problem, but
>> have no idea how to fix it. Here's that section in the configuration doc:
>> <gml:baseCRS>
>> <fdo:WKTCRS gml:id="Default">
>> <gml:srsName>Default</gml:srsName>
>> <fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
>> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
>> </fdo:WKTCRS>
>> </gml:baseCRS>
>> <gml:definedByConversion
>> xlink:href="http://fdo.osgeo.org/coord_conversions#identity" />
>> <gml:derivedCRSType
>> codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType>
>> <gml:usesCS xlink:href="http://fdo.osgeo.org/cs#default_cartesian" />
>> </gml:DerivedCRS>
>> Andrew
>>> Create a new GDal raster (or open an existing).
>>> In the "Type" field select "Composite".
>>> Now add files and folders in the list below.
>>>> The Gdalnotes wiki says:
>>>> "With the release of FDOGDAL 3.2.3, Frank has added support for
>>>> tile indexes in an XML config file.
>>>> MapGuide Maestro <http://trac.osgeo.org/mapguide/wiki/maestro> will
>>>> allow you to create these tile indexes in an intuitive GUI."
>>>> Where do I find that gui?
>>>> Andrew
>>>> *Andrew DeMerchant*
>>>> *Computer Technologist*
>>>> ph.1-877-2GEMTEC x.163
>>>> fax 506-453-9470
>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>> /191 Doak Road
>>>> Fredericton, NB, Canada
>>>> E3C 2E6
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> *Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
