[mapguide-users] image tile indexes from Maestro?
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Jun 12 10:12:41 EDT 2008
Right you are - reinstalling did a whole lot of nothing. It's so strange
that they've just gone missing....I've done nothing to the server. I've
tried the csenumeratecategoriesform.html link you suggested in the trac,
and I do only get that one category...I've tried copying my
categories.txt file (and restarting the server) to the nad folder, but
no luck. It's definitely still working fine with coord systems though. I
just can't actually set any in Maestro, which is pretty annoying.
Kenneth Skovhede, GEOGRAF A/S wrote:
> I don't think re-installing Maestro will help.
> AFAIK MapGuide needs two setups for coordinate systems, one for
> MapGuide and one for the WebTier.
> Maestro only has access to the WebTier, so everything may work fine,
> but you cannot see the coordinate systems.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Andrew DeMerchant skrev:
>> Odd, since it's been working fine all along....I'm going to try
>> reinstalling Maestro. As for my image layer - I've managed to get it
>> to show up now, but it's totally crazy. If I do a layer preview in
>> Studio, I see a single image - should be about 6....and it's scale is
>> messed up, because I have to zoom way way out to see it.
>> Andrew
>>> I think you are having a problem with MapGuide's coordinate system:
>>> http://trac.osgeo.org/mapguide/ticket/582
>>>> Ah. Easy....thanks! Now when I did that, of course, my coords
>>>> system overrides got messed up and I can't seem to fix them from
>>>> Maestro (or anywhere, so far) - In Maestro, all I get in my coord
>>>> category list is Arbitrary X-Y....If I just paste in the correct
>>>> string, it'll take it - but every time I refresh my overrides, it
>>>> adds a Default in XY-MT. If I look at the configuration document
>>>> using Studio, I see that it's got some coord system stuff in it (in
>>>> <fdo:WKT>), and that it's wrong (it's using XY-MT). I'm guessing
>>>> this is the problem, but have no idea how to fix it. Here's that
>>>> section in the configuration doc:
>>>> <gml:baseCRS>
>>>> <fdo:WKTCRS gml:id="Default">
>>>> <gml:srsName>Default</gml:srsName>
>>>> <fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
>>>> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
>>>> </fdo:WKTCRS>
>>>> </gml:baseCRS>
>>>> <gml:definedByConversion
>>>> xlink:href="http://fdo.osgeo.org/coord_conversions#identity" />
>>>> <gml:derivedCRSType
>>>> codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType>
>>>> <gml:usesCS
>>>> xlink:href="http://fdo.osgeo.org/cs#default_cartesian" />
>>>> </gml:DerivedCRS>
>>>> Andrew
>>>>> Create a new GDal raster (or open an existing).
>>>>> In the "Type" field select "Composite".
>>>>> Now add files and folders in the list below.
>>>>>> The Gdalnotes wiki says:
>>>>>> "With the release of FDOGDAL 3.2.3, Frank has added support for
>>>>>> tile indexes in an XML config file.
>>>>>> MapGuide Maestro <http://trac.osgeo.org/mapguide/wiki/maestro>
>>>>>> will allow you to create these tile indexes in an intuitive GUI."
>>>>>> Where do I find that gui?
>>>>>> Andrew
>>>>>> *Andrew DeMerchant*
>>>>>> *Computer Technologist*
>>>>>> ph.1-877-2GEMTEC x.163
>>>>>> fax 506-453-9470
>>>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>>>> /191 Doak Road
>>>>>> Fredericton, NB, Canada
>>>>>> E3C 2E6
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> *Andrew DeMerchant*
>>>> fax 506-453-9470
>>>> /191 Doak Road
>>>> E3C 2E6
>> *Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
