[mapguide-users] image tile indexes from Maestro?
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Jun 12 10:36:40 EDT 2008
I finally got it running, after copying the categories.txt file all over
the installation.
But I don't know what location made it work.
Regards, Kenneth Skovhede, GEOGRAF A/S
Andrew DeMerchant skrev:
> Right you are - reinstalling did a whole lot of nothing. It's so
> strange that they've just gone missing....I've done nothing to the
> server. I've tried the csenumeratecategoriesform.html link you
> suggested in the trac, and I do only get that one category...I've
> tried copying my categories.txt file (and restarting the server) to
> the nad folder, but no luck. It's definitely still working fine with
> coord systems though. I just can't actually set any in Maestro, which
> is pretty annoying.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> I don't think re-installing Maestro will help.
>> AFAIK MapGuide needs two setups for coordinate systems, one for
>> MapGuide and one for the WebTier.
>> Maestro only has access to the WebTier, so everything may work fine,
>> but you cannot see the coordinate systems.
>>> Odd, since it's been working fine all along....I'm going to try
>>> reinstalling Maestro. As for my image layer - I've managed to get it
>>> to show up now, but it's totally crazy. If I do a layer preview in
>>> Studio, I see a single image - should be about 6....and it's scale
>>> is messed up, because I have to zoom way way out to see it.
>>> Andrew
>>>> I think you are having a problem with MapGuide's coordinate system:
>>>> http://trac.osgeo.org/mapguide/ticket/582
>>>>> Ah. Easy....thanks! Now when I did that, of course, my coords
>>>>> system overrides got messed up and I can't seem to fix them from
>>>>> Maestro (or anywhere, so far) - In Maestro, all I get in my coord
>>>>> category list is Arbitrary X-Y....If I just paste in the correct
>>>>> string, it'll take it - but every time I refresh my overrides, it
>>>>> adds a Default in XY-MT. If I look at the configuration document
>>>>> using Studio, I see that it's got some coord system stuff in it
>>>>> (in <fdo:WKT>), and that it's wrong (it's using XY-MT). I'm
>>>>> guessing this is the problem, but have no idea how to fix it.
>>>>> Here's that section in the configuration doc:
>>>>> <gml:baseCRS>
>>>>> <fdo:WKTCRS gml:id="Default">
>>>>> <gml:srsName>Default</gml:srsName>
>>>>> <fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
>>>>> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
>>>>> </fdo:WKTCRS>
>>>>> </gml:baseCRS>
>>>>> <gml:definedByConversion
>>>>> xlink:href="http://fdo.osgeo.org/coord_conversions#identity" />
>>>>> <gml:derivedCRSType
>>>>> codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType>
>>>>> <gml:usesCS
>>>>> xlink:href="http://fdo.osgeo.org/cs#default_cartesian" />
>>>>> </gml:DerivedCRS>
>>>>> Andrew
>>>>>> Create a new GDal raster (or open an existing).
>>>>>> In the "Type" field select "Composite".
>>>>>> Now add files and folders in the list below.
>>>>>>> The Gdalnotes wiki says:
>>>>>>> "With the release of FDOGDAL 3.2.3, Frank has added support for
>>>>>>> tile indexes in an XML config file.
>>>>>>> MapGuide Maestro <http://trac.osgeo.org/mapguide/wiki/maestro>
>>>>>>> will allow you to create these tile indexes in an intuitive GUI."
>>>>>>> Where do I find that gui?
>>>>>>> Andrew
>>>>>>> *Andrew DeMerchant*
>>>>>>> *Computer Technologist*
>>>>>>> ph.1-877-2GEMTEC x.163
>>>>>>> fax 506-453-9470
>>>>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>>>>> /191 Doak Road
>>>>>>> Fredericton, NB, Canada
>>>>>>> E3C 2E6
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>> *Andrew DeMerchant*
>>>>> fax 506-453-9470
>>>>> /191 Doak Road
>>>>> E3C 2E6
>>> *Andrew DeMerchant*
>>> fax 506-453-9470
>>> /191 Doak Road
>>> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
Skipped content of type multipart/related
