[mapguide-users] image tile indexes from Maestro?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu Jun 12 12:50:35 EDT 2008
I just copied it to every single folder in Server and
WebExtensions.....no luck. Are you sure that it can't be Maestro? It
really did work fine until I tried that composite gdal thing.....
Andrew
Kenneth Skovhede, GEOGRAF A/S wrote:
> I finally got it running, after copying the categories.txt file all
> over the installation.
> But I don't know what location made it work.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Andrew DeMerchant skrev:
>> Right you are - reinstalling did a whole lot of nothing. It's so
>> strange that they've just gone missing....I've done nothing to the
>> server. I've tried the csenumeratecategoriesform.html link you
>> suggested in the trac, and I do only get that one category...I've
>> tried copying my categories.txt file (and restarting the server) to
>> the nad folder, but no luck. It's definitely still working fine with
>> coord systems though. I just can't actually set any in Maestro, which
>> is pretty annoying.
>>> I don't think re-installing Maestro will help.
>>> AFAIK MapGuide needs two setups for coordinate systems, one for
>>> MapGuide and one for the WebTier.
>>> Maestro only has access to the WebTier, so everything may work fine,
>>> but you cannot see the coordinate systems.
>>>> Odd, since it's been working fine all along....I'm going to try
>>>> reinstalling Maestro. As for my image layer - I've managed to get
>>>> it to show up now, but it's totally crazy. If I do a layer preview
>>>> in Studio, I see a single image - should be about 6....and it's
>>>> scale is messed up, because I have to zoom way way out to see it.
>>>> Andrew
>>>>> I think you are having a problem with MapGuide's coordinate system:
>>>>> http://trac.osgeo.org/mapguide/ticket/582
>>>>>> Ah. Easy....thanks! Now when I did that, of course, my coords
>>>>>> system overrides got messed up and I can't seem to fix them from
>>>>>> Maestro (or anywhere, so far) - In Maestro, all I get in my coord
>>>>>> category list is Arbitrary X-Y....If I just paste in the correct
>>>>>> string, it'll take it - but every time I refresh my overrides, it
>>>>>> adds a Default in XY-MT. If I look at the configuration document
>>>>>> using Studio, I see that it's got some coord system stuff in it
>>>>>> (in <fdo:WKT>), and that it's wrong (it's using XY-MT). I'm
>>>>>> guessing this is the problem, but have no idea how to fix it.
>>>>>> Here's that section in the configuration doc:
>>>>>>      <gml:baseCRS>
>>>>>>       <fdo:WKTCRS gml:id="Default">
>>>>>>         <gml:srsName>Default</gml:srsName>
>>>>>> <fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
>>>>>> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
>>>>>>       </fdo:WKTCRS>
>>>>>>     </gml:baseCRS>
>>>>>>     <gml:definedByConversion
>>>>>> xlink:href="http://fdo.osgeo.org/coord_conversions#identity" />
>>>>>>     <gml:derivedCRSType
>>>>>> codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType>
>>>>>>     <gml:usesCS
>>>>>> xlink:href="http://fdo.osgeo.org/cs#default_cartesian" />
>>>>>>   </gml:DerivedCRS>
>>>>>> Andrew
>>>>>>> Create a new GDal raster (or open an existing).
>>>>>>> In the "Type" field select "Composite".
>>>>>>> Now add files and folders in the list below.
>>>>>>>> The Gdalnotes wiki says:
>>>>>>>> "With the release of FDOGDAL 3.2.3, Frank has added support for
>>>>>>>> tile indexes in an XML config file.
>>>>>>>> MapGuide Maestro <http://trac.osgeo.org/mapguide/wiki/maestro>
>>>>>>>> will allow you to create these tile indexes in an intuitive GUI."
>>>>>>>> Where do I find that gui?
>>>>>>>> Andrew
>>>>>>>> 	*Andrew DeMerchant*
>>>>>>>> *Computer Technologist*
>>>>>>>> ph.1-877-2GEMTEC x.163
>>>>>>>> fax 506-453-9470
>>>>>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>>>>>> /191 Doak Road
>>>>>>>> Fredericton, NB, Canada
>>>>>>>> E3C 2E6
>>>>>>>> _______________________________________________
>>>>>>>> mapguide-users mailing list
>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>> 	*Andrew DeMerchant*
>>>>>> fax 506-453-9470
>>>>>> /191 Doak Road
>>>>>> E3C 2E6
>>>> 	*Andrew DeMerchant*
>>>> fax 506-453-9470
>>>> /191 Doak Road
>>>> E3C 2E6
>> 	*Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
