[mapguide-users] image tile indexes from Maestro?
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Jun 12 13:06:15 EDT 2008
You may need to restart Maestro after updating the server coordinate system.
Maestro only reads the coordinate systems from the menitoned
csenumeratecategoriesform page.
As long as those do not return categories, Maestro will not either.
Regards, Kenneth Skovhede, GEOGRAF A/S
Andrew DeMerchant skrev:
> I just copied it to every single folder in Server and
> WebExtensions.....no luck. Are you sure that it can't be Maestro? It
> really did work fine until I tried that composite gdal thing.....
> Andrew
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> I finally got it running, after copying the categories.txt file all
>> over the installation.
>> But I don't know what location made it work.
>>> Right you are - reinstalling did a whole lot of nothing. It's so
>>> strange that they've just gone missing....I've done nothing to the
>>> server. I've tried the csenumeratecategoriesform.html link you
>>> suggested in the trac, and I do only get that one category...I've
>>> tried copying my categories.txt file (and restarting the server) to
>>> the nad folder, but no luck. It's definitely still working fine with
>>> coord systems though. I just can't actually set any in Maestro,
>>> which is pretty annoying.
>>>> I don't think re-installing Maestro will help.
>>>> AFAIK MapGuide needs two setups for coordinate systems, one for
>>>> MapGuide and one for the WebTier.
>>>> Maestro only has access to the WebTier, so everything may work
>>>> fine, but you cannot see the coordinate systems.
>>>>> Odd, since it's been working fine all along....I'm going to try
>>>>> reinstalling Maestro. As for my image layer - I've managed to get
>>>>> it to show up now, but it's totally crazy. If I do a layer preview
>>>>> in Studio, I see a single image - should be about 6....and it's
>>>>> scale is messed up, because I have to zoom way way out to see it.
>>>>> Andrew
>>>>>> I think you are having a problem with MapGuide's coordinate system:
>>>>>> http://trac.osgeo.org/mapguide/ticket/582
>>>>>>> Ah. Easy....thanks! Now when I did that, of course, my coords
>>>>>>> system overrides got messed up and I can't seem to fix them from
>>>>>>> Maestro (or anywhere, so far) - In Maestro, all I get in my
>>>>>>> coord category list is Arbitrary X-Y....If I just paste in the
>>>>>>> correct string, it'll take it - but every time I refresh my
>>>>>>> overrides, it adds a Default in XY-MT. If I look at the
>>>>>>> configuration document using Studio, I see that it's got some
>>>>>>> coord system stuff in it (in <fdo:WKT>), and that it's wrong
>>>>>>> (it's using XY-MT). I'm guessing this is the problem, but have
>>>>>>> no idea how to fix it. Here's that section in the configuration doc:
>>>>>>> <gml:baseCRS>
>>>>>>> <fdo:WKTCRS gml:id="Default">
>>>>>>> <gml:srsName>Default</gml:srsName>
>>>>>>> <fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
>>>>>>> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
>>>>>>> </fdo:WKTCRS>
>>>>>>> </gml:baseCRS>
>>>>>>> <gml:definedByConversion
>>>>>>> xlink:href="http://fdo.osgeo.org/coord_conversions#identity" />
>>>>>>> <gml:derivedCRSType
>>>>>>> codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType>
>>>>>>> <gml:usesCS
>>>>>>> xlink:href="http://fdo.osgeo.org/cs#default_cartesian" />
>>>>>>> </gml:DerivedCRS>
>>>>>>> Andrew
>>>>>>>> Create a new GDal raster (or open an existing).
>>>>>>>> In the "Type" field select "Composite".
>>>>>>>> Now add files and folders in the list below.
>>>>>>>>> The Gdalnotes wiki says:
>>>>>>>>> "With the release of FDOGDAL 3.2.3, Frank has added support
>>>>>>>>> for tile indexes in an XML config file.
>>>>>>>>> MapGuide Maestro <http://trac.osgeo.org/mapguide/wiki/maestro>
>>>>>>>>> will allow you to create these tile indexes in an intuitive GUI."
>>>>>>>>> Where do I find that gui?
>>>>>>>>> Andrew
>>>>>>>>> *Andrew DeMerchant*
>>>>>>>>> *Computer Technologist*
>>>>>>>>> ph.1-877-2GEMTEC x.163
>>>>>>>>> fax 506-453-9470
>>>>>>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>>>>>>> /191 Doak Road
>>>>>>>>> Fredericton, NB, Canada
>>>>>>>>> E3C 2E6
>>>>>>>>> _______________________________________________
>>>>>>>>> mapguide-users mailing list
>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>>> *Andrew DeMerchant*
>>>>>>> fax 506-453-9470
>>>>>>> /191 Doak Road
>>>>>>> E3C 2E6
>>>>> *Andrew DeMerchant*
>>>>> fax 506-453-9470
>>>>> /191 Doak Road
>>>>> E3C 2E6
>>> *Andrew DeMerchant*
>>> fax 506-453-9470
>>> /191 Doak Road
>>> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
Skipped content of type multipart/related
