[mapguide-users] image tile indexes from Maestro?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu Jun 12 13:28:26 EDT 2008
I've restarted everything.....I'm stumped. I found your post about this
from Aug 2007, and have checked the registry - I tried changing it to
various things, and restarting the server.....no luck. I'm going to try
repairing my MGOS installation...maybe reinstalling.
Andrew
Kenneth Skovhede, GEOGRAF A/S wrote:
> You may need to restart Maestro after updating the server coordinate
> system.
> Maestro only reads the coordinate systems from the menitoned
> csenumeratecategoriesform page.
> As long as those do not return categories, Maestro will not either.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Andrew DeMerchant skrev:
>> I just copied it to every single folder in Server and
>> WebExtensions.....no luck. Are you sure that it can't be Maestro? It
>> really did work fine until I tried that composite gdal thing.....
>> Andrew
>>> I finally got it running, after copying the categories.txt file all
>>> over the installation.
>>> But I don't know what location made it work.
>>>> Right you are - reinstalling did a whole lot of nothing. It's so
>>>> strange that they've just gone missing....I've done nothing to the
>>>> server. I've tried the csenumeratecategoriesform.html link you
>>>> suggested in the trac, and I do only get that one category...I've
>>>> tried copying my categories.txt file (and restarting the server) to
>>>> the nad folder, but no luck. It's definitely still working fine
>>>> with coord systems though. I just can't actually set any in
>>>> Maestro, which is pretty annoying.
>>>>> I don't think re-installing Maestro will help.
>>>>> AFAIK MapGuide needs two setups for coordinate systems, one for
>>>>> MapGuide and one for the WebTier.
>>>>> Maestro only has access to the WebTier, so everything may work
>>>>> fine, but you cannot see the coordinate systems.
>>>>>> Odd, since it's been working fine all along....I'm going to try
>>>>>> reinstalling Maestro. As for my image layer - I've managed to get
>>>>>> it to show up now, but it's totally crazy. If I do a layer
>>>>>> preview in Studio, I see a single image - should be about
>>>>>> 6....and it's scale is messed up, because I have to zoom way way
>>>>>> out to see it.
>>>>>> Andrew
>>>>>>> I think you are having a problem with MapGuide's coordinate system:
>>>>>>> http://trac.osgeo.org/mapguide/ticket/582
>>>>>>>> Ah. Easy....thanks! Now when I did that, of course, my coords
>>>>>>>> system overrides got messed up and I can't seem to fix them
>>>>>>>> from Maestro (or anywhere, so far) - In Maestro, all I get in
>>>>>>>> my coord category list is Arbitrary X-Y....If I just paste in
>>>>>>>> the correct string, it'll take it - but every time I refresh my
>>>>>>>> overrides, it adds a Default in XY-MT. If I look at the
>>>>>>>> configuration document using Studio, I see that it's got some
>>>>>>>> coord system stuff in it (in <fdo:WKT>), and that it's wrong
>>>>>>>> (it's using XY-MT). I'm guessing this is the problem, but have
>>>>>>>> no idea how to fix it. Here's that section in the configuration
>>>>>>>> doc:
>>>>>>>>      <gml:baseCRS>
>>>>>>>>       <fdo:WKTCRS gml:id="Default">
>>>>>>>>         <gml:srsName>Default</gml:srsName>
>>>>>>>> <fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
>>>>>>>> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
>>>>>>>>       </fdo:WKTCRS>
>>>>>>>>     </gml:baseCRS>
>>>>>>>>     <gml:definedByConversion
>>>>>>>> xlink:href="http://fdo.osgeo.org/coord_conversions#identity" />
>>>>>>>>     <gml:derivedCRSType
>>>>>>>> codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType>
>>>>>>>>     <gml:usesCS
>>>>>>>> xlink:href="http://fdo.osgeo.org/cs#default_cartesian" />
>>>>>>>>   </gml:DerivedCRS>
>>>>>>>> Andrew
>>>>>>>>> Create a new GDal raster (or open an existing).
>>>>>>>>> In the "Type" field select "Composite".
>>>>>>>>> Now add files and folders in the list below.
>>>>>>>>>> The Gdalnotes wiki says:
>>>>>>>>>> "With the release of FDOGDAL 3.2.3, Frank has added support
>>>>>>>>>> for tile indexes in an XML config file.
>>>>>>>>>> MapGuide Maestro
>>>>>>>>>> <http://trac.osgeo.org/mapguide/wiki/maestro> will allow you
>>>>>>>>>> to create these tile indexes in an intuitive GUI."
>>>>>>>>>> Where do I find that gui?
>>>>>>>>>> Andrew
>>>>>>>>>> 	*Andrew DeMerchant*
>>>>>>>>>> *Computer Technologist*
>>>>>>>>>> ph.1-877-2GEMTEC x.163
>>>>>>>>>> fax 506-453-9470
>>>>>>>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>>>>>>>> /191 Doak Road
>>>>>>>>>> Fredericton, NB, Canada
>>>>>>>>>> E3C 2E6
>>>>>>>>>> _______________________________________________
>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>>>> 	*Andrew DeMerchant*
>>>>>>>> fax 506-453-9470
>>>>>>>> /191 Doak Road
>>>>>>>> E3C 2E6
>>>>>> 	*Andrew DeMerchant*
>>>>>> fax 506-453-9470
>>>>>> /191 Doak Road
>>>>>> E3C 2E6
>>>> 	*Andrew DeMerchant*
>>>> fax 506-453-9470
>>>> /191 Doak Road
>>>> E3C 2E6
>> 	*Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
