[mapguide-users] image tile indexes from Maestro?
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Jun 12 14:38:26 EDT 2008
Ok - repairing didn't work.....but reinstalling both Server and Webex
did the trick. I wish there had been an easier way - but at least it's
working now.
Andrew DeMerchant wrote:
> I've restarted everything.....I'm stumped. I found your post about
> this from Aug 2007, and have checked the registry - I tried changing
> it to various things, and restarting the server.....no luck. I'm going
> to try repairing my MGOS installation...maybe reinstalling.
> Andrew
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> You may need to restart Maestro after updating the server coordinate
>> system.
>> Maestro only reads the coordinate systems from the menitoned
>> csenumeratecategoriesform page.
>> As long as those do not return categories, Maestro will not either.
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Andrew DeMerchant skrev:
>>> I just copied it to every single folder in Server and
>>> WebExtensions.....no luck. Are you sure that it can't be Maestro? It
>>> really did work fine until I tried that composite gdal thing.....
>>> Andrew
>>>> I finally got it running, after copying the categories.txt file all
>>>> over the installation.
>>>> But I don't know what location made it work.
>>>>> Right you are - reinstalling did a whole lot of nothing. It's so
>>>>> strange that they've just gone missing....I've done nothing to the
>>>>> server. I've tried the csenumeratecategoriesform.html link you
>>>>> suggested in the trac, and I do only get that one category...I've
>>>>> tried copying my categories.txt file (and restarting the server)
>>>>> to the nad folder, but no luck. It's definitely still working fine
>>>>> with coord systems though. I just can't actually set any in
>>>>> Maestro, which is pretty annoying.
>>>>>> I don't think re-installing Maestro will help.
>>>>>> AFAIK MapGuide needs two setups for coordinate systems, one for
>>>>>> MapGuide and one for the WebTier.
>>>>>> Maestro only has access to the WebTier, so everything may work
>>>>>> fine, but you cannot see the coordinate systems.
>>>>>>> Odd, since it's been working fine all along....I'm going to try
>>>>>>> reinstalling Maestro. As for my image layer - I've managed to
>>>>>>> get it to show up now, but it's totally crazy. If I do a layer
>>>>>>> preview in Studio, I see a single image - should be about
>>>>>>> 6....and it's scale is messed up, because I have to zoom way way
>>>>>>> out to see it.
>>>>>>> Andrew
>>>>>>>> I think you are having a problem with MapGuide's coordinate system:
>>>>>>>> http://trac.osgeo.org/mapguide/ticket/582
>>>>>>>>> Ah. Easy....thanks! Now when I did that, of course, my coords
>>>>>>>>> system overrides got messed up and I can't seem to fix them
>>>>>>>>> from Maestro (or anywhere, so far) - In Maestro, all I get in
>>>>>>>>> my coord category list is Arbitrary X-Y....If I just paste in
>>>>>>>>> the correct string, it'll take it - but every time I refresh
>>>>>>>>> my overrides, it adds a Default in XY-MT. If I look at the
>>>>>>>>> configuration document using Studio, I see that it's got some
>>>>>>>>> coord system stuff in it (in <fdo:WKT>), and that it's wrong
>>>>>>>>> (it's using XY-MT). I'm guessing this is the problem, but have
>>>>>>>>> no idea how to fix it. Here's that section in the
>>>>>>>>> configuration doc:
>>>>>>>>> <gml:baseCRS>
>>>>>>>>> <fdo:WKTCRS gml:id="Default">
>>>>>>>>> <gml:srsName>Default</gml:srsName>
>>>>>>>>> <fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
>>>>>>>>> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
>>>>>>>>> </fdo:WKTCRS>
>>>>>>>>> </gml:baseCRS>
>>>>>>>>> <gml:definedByConversion
>>>>>>>>> xlink:href="http://fdo.osgeo.org/coord_conversions#identity" />
>>>>>>>>> <gml:derivedCRSType
>>>>>>>>> codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType>
>>>>>>>>> <gml:usesCS
>>>>>>>>> xlink:href="http://fdo.osgeo.org/cs#default_cartesian" />
>>>>>>>>> </gml:DerivedCRS>
>>>>>>>>> Andrew
>>>>>>>>>> Create a new GDal raster (or open an existing).
>>>>>>>>>> In the "Type" field select "Composite".
>>>>>>>>>> Now add files and folders in the list below.
>>>>>>>>>>> The Gdalnotes wiki says:
>>>>>>>>>>> "With the release of FDOGDAL 3.2.3, Frank has added support
>>>>>>>>>>> for tile indexes in an XML config file.
>>>>>>>>>>> MapGuide Maestro
>>>>>>>>>>> <http://trac.osgeo.org/mapguide/wiki/maestro> will allow you
>>>>>>>>>>> to create these tile indexes in an intuitive GUI."
>>>>>>>>>>> Where do I find that gui?
>>>>>>>>>>> Andrew
>>>>>>>>>>> *Andrew DeMerchant*
>>>>>>>>>>> *Computer Technologist*
>>>>>>>>>>> ph.1-877-2GEMTEC x.163
>>>>>>>>>>> fax 506-453-9470
>>>>>>>>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>>>>>>>>> /191 Doak Road
>>>>>>>>>>> Fredericton, NB, Canada
>>>>>>>>>>> E3C 2E6
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>>>>> *Andrew DeMerchant*
>>>>>>>>> fax 506-453-9470
>>>>>>>>> /191 Doak Road
>>>>>>>>> E3C 2E6
>>>>>>> *Andrew DeMerchant*
>>>>>>> fax 506-453-9470
>>>>>>> /191 Doak Road
>>>>>>> E3C 2E6
>>>>> *Andrew DeMerchant*
>>>>> fax 506-453-9470
>>>>> /191 Doak Road
>>>>> E3C 2E6
>>> *Andrew DeMerchant*
>>> fax 506-453-9470
>>> /191 Doak Road
>>> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
