[mapguide-users] image tile indexes from Maestro?
Danas Augutis
dumas65 at gmail.com
Thu Jun 12 10:19:25 EDT 2008
I'm Playing with this function to. The problem is that in XML i get wrong
cordinates for tiff files:
<Location name="E:\Data\ORT10LT-2006\2\">
<Feature name="2146">
<Band name="RGB" number="1">
<Image frame="1" name="2146.tfw">
<Bounds>
<MinX>-10000000</MinX>
<MinY>-10000000</MinY>
<MaxX>10000000</MaxX>
<MaxY>10000000</MaxY>
</Bounds>
</Image>
</Band>
</Feature>
<Image frame="1" name="2146.tif">
<Bounds>
</Bounds>
</Image>
</Band>
</Feature>
I think I'm missing something basic here. Why world files are not detected?
If I add same data using alias, everythink works fine.
On Thursday 12 June 2008 17:08:18 Kenneth Skovhede, GEOGRAF A/S wrote:
> I don't think re-installing Maestro will help.
> AFAIK MapGuide needs two setups for coordinate systems, one for MapGuide
> and one for the WebTier.
> Maestro only has access to the WebTier, so everything may work fine, but
> you cannot see the coordinate systems.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Andrew DeMerchant skrev:
> > Odd, since it's been working fine all along....I'm going to try
> > reinstalling Maestro. As for my image layer - I've managed to get it
> > to show up now, but it's totally crazy. If I do a layer preview in
> > Studio, I see a single image - should be about 6....and it's scale is
> > messed up, because I have to zoom way way out to see it.
> > Andrew
> >> I think you are having a problem with MapGuide's coordinate system:
> >> http://trac.osgeo.org/mapguide/ticket/582
> >>> Ah. Easy....thanks! Now when I did that, of course, my coords system
> >>> overrides got messed up and I can't seem to fix them from Maestro
> >>> (or anywhere, so far) - In Maestro, all I get in my coord category
> >>> list is Arbitrary X-Y....If I just paste in the correct string,
> >>> it'll take it - but every time I refresh my overrides, it adds a
> >>> Default in XY-MT. If I look at the configuration document using
> >>> Studio, I see that it's got some coord system stuff in it (in
> >>> <fdo:WKT>), and that it's wrong (it's using XY-MT). I'm guessing
> >>> this is the problem, but have no idea how to fix it. Here's that
> >>> section in the configuration doc:
> >>> <gml:baseCRS>
> >>> <fdo:WKTCRS gml:id="Default">
> >>> <gml:srsName>Default</gml:srsName>
> >>> <fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
> >>> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
> >>> </fdo:WKTCRS>
> >>> </gml:baseCRS>
> >>> <gml:definedByConversion
> >>> xlink:href="http://fdo.osgeo.org/coord_conversions#identity" />
> >>> <gml:derivedCRSType
> >>> codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSTy
> >>>pe> <gml:usesCS
> >>> xlink:href="http://fdo.osgeo.org/cs#default_cartesian" />
> >>> </gml:DerivedCRS>
> >>> Andrew
> >>>> Create a new GDal raster (or open an existing).
> >>>> In the "Type" field select "Composite".
> >>>> Now add files and folders in the list below.
> >>>>> The Gdalnotes wiki says:
> >>>>> "With the release of FDOGDAL 3.2.3, Frank has added support for
> >>>>> tile indexes in an XML config file.
> >>>>> MapGuide Maestro <http://trac.osgeo.org/mapguide/wiki/maestro>
> >>>>> will allow you to create these tile indexes in an intuitive GUI."
> >>>>> Where do I find that gui?
> >>>>> Andrew
> >>>>> *Andrew DeMerchant*
> >>>>> *Computer Technologist*
> >>>>> ph.1-877-2GEMTEC x.163
> >>>>> fax 506-453-9470
> >>>>> /GEMTEC Limited <http://www.gemtec.ca>
> >>>>> /191 Doak Road
> >>>>> Fredericton, NB, Canada
> >>>>> E3C 2E6
> >>>>> _______________________________________________
> >>>>> mapguide-users mailing list
> >>>>> mapguide-users at lists.osgeo.org
> >>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> >>> *Andrew DeMerchant*
> >>> fax 506-453-9470
> >>> /191 Doak Road
> >>> E3C 2E6
> > *Andrew DeMerchant*
> > fax 506-453-9470
> > /191 Doak Road
> > E3C 2E6
