[mapguide-users] Problem in the GenerateFilter() method of
theMgSelection class
Bruno Scott
bscott at geomapgis.com
Thu Jun 12 12:07:57 EDT 2008
I've just made some test on version 2.0 and 2.01 and the bug is still there
I've gone further on my test
I have the same problem on a polyline layer using the PostGIS provider
I have another application using the AUtodesk.oracle provider and i have a
similar problem
but it is not the ids (248, 249, 250, 251) + the magic number (256)
but 255 + the magic number (256) s0 can't get selection on ids
255,511,767,...
I can reproduce the problem on a polyline table on the same database
neither on a x,y table using odbc provider
Patrick Chevalier wrote:
> Here is the ticket on the Trac instance :
> http://trac.osgeo.org/mapguide/ticket/354
> Thank you very much
> JasonBirch wrote:
>> That's a pretty insane bug...
>> Can you please file a ticket for this on our Trac instance here?
>> http://trac.osgeo.org/mapguide/wiki/SubmitTicket
>> Your problem description is quite good; please ensuee that you also
>> specify version, platform, etc in the ticket.
>> Thanks,
>> Jason
>> -----Original Message-----
>> From: Patrick Chevalier
>> Subject: Re: [mapguide-users] Problem in the GenerateFilter() method of
>> I just want to mention that this problem is really blocking because 1
>> out of 50 entities CANNOT be retrieved into an MgSelection. That means
>> that I cannot guarantee my clients that my applications are bug free
>> because they encountered this problem and I can't give them any bug fix.
>> I hope somebody will help me find a solution very soon.
>>> I built a little web application that demonstrates the bug in the
>>> GenerateFilter() method of the MgSelection class.
>>> The bug seems to happen on a precise pattern inside the Feature
>>> Sources and only on the Identity field.
>>> The program demonstrate that no matter which SDF or SHP used (I only
>>> tested these two), the GenerateFilter() method returns a random ID
>>> instead of returning the correct FeatId (Identity). You can use your
>>> SDF to test it too.
>>> Always the same FeatIds are wrong :
>>> It starts with the ID 248 for 4 polygons, and step by 256 after that.
>>> 248, 249, 250, 251
>>> 504, 505, 506, 507
>>> 760, 761, 762, 763
>>> ... and so on.
>>> You can download the application at this address :
>>> http://www.geomapgis.ca/webdownloads/MAPGUIDE_ERROR.zip
>>> Start by reading the ReadMe.txt file.
>>> Be sure to give access to user ASPNET to your web folder application.
>>> Thanks to anyone that may have a solution to this problem!
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Problem-in-the-GenerateFilter%28%29-method-of-the-MgSelection-class-tp14132755p17803667.html
