[mapguide-users] image tile indexes from Maestro?
Dumas A
dumas65 at gmail.com
Fri Jun 13 03:02:35 EDT 2008
That's weird. Today I rechecked configs and discovered that in
rasterconfig.php path to server was left default (c:\programfile..etc) but
my installation is in f: so both paths (server dir and wer dir) are wrong.
However, Raster Config Builder builds recourse almost successfully (resource
is shown without tiling information). How can can it be?
I'm starting to think that this is not only Maetro bug, but something really
deeper.
Any way, will try to add ticket as promissed
D.
On Thu, Jun 12, 2008 at 8:23 PM, Kenneth Skovhede, GEOGRAF A/S <
ks at geograf.dk> wrote:
> That is very odd.
> If you can explain how I can reproduce a similar situation on my machine, I
> am willing to try it out.
> If so, can you please create a ticket for the problem:
> http://trac.osgeo.org/mapguide/newticket
> (You must sign in, and select Maestro as the component)
> If I can download some of the files somewhere, I can try it out.
> You can mail me directly with instructions, and I will keep the information
> and files confident.
> Regards. Kenneth Skovhede, GEOGRAF A/S
> Dumas A skrev:
> If I add alias (directory with same tiffs) to datasource, map is displayed
> correctly. I tried to add geo tiff or ecw via composite mode it loses
> coordinate information to. I was thinking it is problem with world files,
> but it seems that it is problem in gdal, mapguide maestro or MGOS.
> Any Ideas how to solve it?
> P.S. I tried to add tiles data vie php script found in FDO website
> (rasterconfig.php). same problem too... :(
> On Thu, Jun 12, 2008 at 6:30 PM, Kenneth Skovhede, GEOGRAF A/S <
>> I have seen this happen when the images are not accepted by GDAL.
>> For some reason it does not return an error, but rather some large values.
>> What happens if you try to use a single file (ea. not composite mode)?
>> Do you get the correct coordinate system?
>> If not, you can try to debug with the regular raster debug guide:
>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Danas Augutis skrev:
>> I'm Playing with this function to. The problem is that in XML i get wrong
>> cordinates for tiff files:
>> <Location name="E:\Data\ORT10LT-2006\2\">
>> <Feature name="2146">
>> <Band name="RGB" number="1">
>> <Image frame="1" name="2146.tfw">
>> <Bounds>
>> <MinX>-10000000</MinX>
>> <MinY>-10000000</MinY>
>> <MaxX>10000000</MaxX>
>> <MaxY>10000000</MaxY>
>> </Bounds>
>> </Image>
>> </Band>
>> </Feature>
>> <Image frame="1" name="2146.tif">
>> <Bounds>
>> </Bounds>
>> </Image>
>> </Band>
>> </Feature>
>> I think I'm missing something basic here. Why world files are not detected?
>> If I add same data using alias, everythink works fine.
>> On Thursday 12 June 2008 17:08:18 Kenneth Skovhede, GEOGRAF A/S wrote:
>> I don't think re-installing Maestro will help.
>> AFAIK MapGuide needs two setups for coordinate systems, one for MapGuide
>> and one for the WebTier.
>> Maestro only has access to the WebTier, so everything may work fine, but
>> you cannot see the coordinate systems.
>> Andrew DeMerchant skrev:
>> Odd, since it's been working fine all along....I'm going to try
>> reinstalling Maestro. As for my image layer - I've managed to get it
>> to show up now, but it's totally crazy. If I do a layer preview in
>> Studio, I see a single image - should be about 6....and it's scale is
>> messed up, because I have to zoom way way out to see it.
>> Andrew
>> I think you are having a problem with MapGuide's coordinate system:
>> http://trac.osgeo.org/mapguide/ticket/582
>> Ah. Easy....thanks! Now when I did that, of course, my coords system
>> overrides got messed up and I can't seem to fix them from Maestro
>> (or anywhere, so far) - In Maestro, all I get in my coord category
>> list is Arbitrary X-Y....If I just paste in the correct string,
>> it'll take it - but every time I refresh my overrides, it adds a
>> Default in XY-MT. If I look at the configuration document using
>> Studio, I see that it's got some coord system stuff in it (in
>> <fdo:WKT>), and that it's wrong (it's using XY-MT). I'm guessing
>> this is the problem, but have no idea how to fix it. Here's that
>> section in the configuration doc:
>> <gml:baseCRS>
>> <fdo:WKTCRS gml:id="Default">
>> <gml:srsName>Default</gml:srsName>
>> <fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
>> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
>> </fdo:WKTCRS>
>> </gml:baseCRS>
>> <gml:definedByConversion
>> xlink:href="http://fdo.osgeo.org/coord_conversions#identity" <http://fdo.osgeo.org/coord_conversions#identity> />
>> <gml:derivedCRSType
>> codeSpace="http://fdo.osgeo.org/crs_types" <http://fdo.osgeo.org/crs_types>>geographic</gml:derivedCRSTy
>> pe> <gml:usesCS
>> xlink:href="http://fdo.osgeo.org/cs#default_cartesian" <http://fdo.osgeo.org/cs#default_cartesian> />
>> </gml:DerivedCRS>
>> Andrew
>> Create a new GDal raster (or open an existing).
>> In the "Type" field select "Composite".
>> Now add files and folders in the list below.
>> The Gdalnotes wiki says:
>> "With the release of FDOGDAL 3.2.3, Frank has added support for
>> tile indexes in an XML config file.
>> MapGuide Maestro <http://trac.osgeo.org/mapguide/wiki/maestro> <http://trac.osgeo.org/mapguide/wiki/maestro>
>> will allow you to create these tile indexes in an intuitive GUI."
>> Where do I find that gui?
>> Andrew
>> *Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca> <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> *Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
>> *Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080613/7ea27f4a/attachment.html
