[mapguide-users] image tile indexes from Maestro?
Danas Augutis dumas65 at gmail.com
Thu Jun 12 13:45:12 EDT 2008
OK, Now I'm at home. Tomorrow I will write all details you need from machine
MGOS is running on.
Thanks,
Danas
On Thursday 12 June 2008 20:23:52 Kenneth Skovhede, GEOGRAF A/S wrote:
> That is very odd.
> If you can explain how I can reproduce a similar situation on my
> machine, I am willing to try it out.
> If so, can you please create a ticket for the problem:
> http://trac.osgeo.org/mapguide/newticket
> (You must sign in, and select Maestro as the component)
> If I can download some of the files somewhere, I can try it out.
> You can mail me directly with instructions, and I will keep the
> information and files confident.
> Regards. Kenneth Skovhede, GEOGRAF A/S
> Dumas A skrev:
> > If I add alias (directory with same tiffs) to datasource, map is
> > displayed correctly. I tried to add geo tiff or ecw via composite mode
> > it loses coordinate information to. I was thinking it is problem with
> > world files, but it seems that it is problem in gdal, mapguide maestro
> > or MGOS.
> > Any Ideas how to solve it?
> > P.S. I tried to add tiles data vie php script found in FDO website
> > (rasterconfig.php). same problem too... :(
> > On Thu, Jun 12, 2008 at 6:30 PM, Kenneth Skovhede, GEOGRAF A/S
> > <ks at geograf.dk <mailto:ks at geograf.dk>> wrote:
> >     I have seen this happen when the images are not accepted by GDAL.
> >     For some reason it does not return an error, but rather some large
> >     values.
> >     What happens if you try to use a single file (ea. not composite
> > mode)? Do you get the correct coordinate system?
> >     If not, you can try to debug with the regular raster debug guide:
> >     http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
> >     Regards, Kenneth Skovhede, GEOGRAF A/S
> >     Danas Augutis skrev:
> >>     I'm Playing with this function to. The problem is that in XML i get
> >> wrong cordinates for tiff files:
> >>     <Location name="E:\Data\ORT10LT-2006\2\">
> >>                 <Feature name="2146">
> >>                   <Band name="RGB" number="1">
> >>                     <Image frame="1" name="2146.tfw">
> >>                       <Bounds>
> >>                         <MinX>-10000000</MinX>
> >>                         <MinY>-10000000</MinY>
> >>                         <MaxX>10000000</MaxX>
> >>                         <MaxY>10000000</MaxY>
> >>                       </Bounds>
> >>                     </Image>
> >>                   </Band>
> >>                 </Feature>
> >>                     <Image frame="1" name="2146.tif">
> >>                       <Bounds>
> >>                       </Bounds>
> >>                     </Image>
> >>                   </Band>
> >>                 </Feature>
> >>     I think I'm missing something basic here. Why world files are not
> >> detected? If I add same data using alias, everythink works fine.
> >>     On Thursday 12 June 2008 17:08:18 Kenneth Skovhede, GEOGRAF A/S
wrote:
> >>>     I don't think re-installing Maestro will help.
> >>>     AFAIK MapGuide needs two setups for coordinate systems, one for
> >>> MapGuide and one for the WebTier.
> >>>     Maestro only has access to the WebTier, so everything may work
> >>> fine, but you cannot see the coordinate systems.
> >>>     Andrew DeMerchant skrev:
> >>>>     Odd, since it's been working fine all along....I'm going to try
> >>>>     reinstalling Maestro. As for my image layer - I've managed to get
> >>>> it to show up now, but it's totally crazy. If I do a layer preview in
> >>>> Studio, I see a single image - should be about 6....and it's scale is
> >>>> messed up, because I have to zoom way way out to see it.
> >>>>     Andrew
> >>>>>     I think you are having a problem with MapGuide's coordinate
> >>>>> system: http://trac.osgeo.org/mapguide/ticket/582
> >>>>>>     Ah. Easy....thanks! Now when I did that, of course, my coords
> >>>>>> system overrides got messed up and I can't seem to fix them from
> >>>>>> Maestro (or anywhere, so far) - In Maestro, all I get in my coord
> >>>>>> category list is Arbitrary X-Y....If I just paste in the correct
> >>>>>> string, it'll take it - but every time I refresh my overrides, it
> >>>>>> adds a Default in XY-MT. If I look at the configuration document
> >>>>>> using Studio, I see that it's got some coord system stuff in it (in
> >>>>>> <fdo:WKT>), and that it's wrong (it's using XY-MT). I'm guessing
> >>>>>> this is the problem, but have no idea how to fix it. Here's that
> >>>>>> section in the configuration doc:
> >>>>>>          <gml:baseCRS>
> >>>>>>           <fdo:WKTCRS gml:id="Default">
> >>>>>>             <gml:srsName>Default</gml:srsName>
> >>>>>> <fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
> >>>>>> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
> >>>>>>           </fdo:WKTCRS>
> >>>>>>         </gml:baseCRS>
> >>>>>>         <gml:definedByConversion
> >>>>>>     xlink:href="http://fdo.osgeo.org/coord_conversions#identity"
> >>>>>> <http://fdo.osgeo.org/coord_conversions#identity> />
> >>>>>> <gml:derivedCRSType
> >>>>>>     codeSpace="http://fdo.osgeo.org/crs_types"
> >>>>>> <http://fdo.osgeo.org/crs_types>>geographic</gml:derivedCRSTy pe>
> >>>>>> <gml:usesCS
> >>>>>>     xlink:href="http://fdo.osgeo.org/cs#default_cartesian"
> >>>>>> <http://fdo.osgeo.org/cs#default_cartesian> /> </gml:DerivedCRS>
> >>>>>>     Andrew
> >>>>>>>     Create a new GDal raster (or open an existing).
> >>>>>>>     In the "Type" field select "Composite".
> >>>>>>>     Now add files and folders in the list below.
> >>>>>>>>     The Gdalnotes wiki says:
> >>>>>>>>     "With the release of FDOGDAL 3.2.3, Frank has added support
> >>>>>>>> for tile indexes in an XML config file.
> >>>>>>>>     MapGuide Maestro <http://trac.osgeo.org/mapguide/wiki/maestro>
> >>>>>>>>     will allow you to create these tile indexes in an intuitive
> >>>>>>>> GUI."
> >>>>>>>>     Where do I find that gui?
> >>>>>>>>     Andrew
> >>>>>>>>     	*Andrew DeMerchant*
> >>>>>>>>     *Computer Technologist*
> >>>>>>>>     ph.1-877-2GEMTEC x.163
> >>>>>>>>     fax 506-453-9470
> >>>>>>>>     /GEMTEC Limited <http://www.gemtec.ca>
> >>>>>>>>     /191 Doak Road
> >>>>>>>>     Fredericton, NB, Canada
> >>>>>>>>     E3C 2E6
> >>>>>>>>     _______________________________________________
> >>>>>>>>     mapguide-users mailing list
> >>>>>>>>     mapguide-users at lists.osgeo.org
> >>>>>>>> <mailto:mapguide-users at lists.osgeo.org>
> >>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> >>>>>>     	*Andrew DeMerchant*
> >>>>>>     fax 506-453-9470
> >>>>>>     /191 Doak Road
> >>>>>>     E3C 2E6
> >>>>     	*Andrew DeMerchant*
> >>>>     fax 506-453-9470
> >>>>     /191 Doak Road
> >>>>     E3C 2E6
