[mapguide-users] image tile indexes from Maestro?
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Jun 12 13:23:52 EDT 2008
That is very odd.
If you can explain how I can reproduce a similar situation on my
machine, I am willing to try it out.
If so, can you please create a ticket for the problem:
http://trac.osgeo.org/mapguide/newticket
(You must sign in, and select Maestro as the component)
If I can download some of the files somewhere, I can try it out.
You can mail me directly with instructions, and I will keep the
information and files confident.
Regards. Kenneth Skovhede, GEOGRAF A/S
Dumas A skrev:
> If I add alias (directory with same tiffs) to datasource, map is
> displayed correctly. I tried to add geo tiff or ecw via composite mode
> it loses coordinate information to. I was thinking it is problem with
> world files, but it seems that it is problem in gdal, mapguide maestro
> or MGOS.
> Any Ideas how to solve it?
> P.S. I tried to add tiles data vie php script found in FDO website
> (rasterconfig.php). same problem too... :(
> On Thu, Jun 12, 2008 at 6:30 PM, Kenneth Skovhede, GEOGRAF A/S
> <ks at geograf.dk <mailto:ks at geograf.dk>> wrote:
> I have seen this happen when the images are not accepted by GDAL.
> For some reason it does not return an error, but rather some large
> values.
> What happens if you try to use a single file (ea. not composite mode)?
> Do you get the correct coordinate system?
> If not, you can try to debug with the regular raster debug guide:
> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Danas Augutis skrev:
>> I'm Playing with this function to. The problem is that in XML i get wrong
>> cordinates for tiff files:
>> <Location name="E:\Data\ORT10LT-2006\2\">
>> <Feature name="2146">
>> <Band name="RGB" number="1">
>> <Image frame="1" name="2146.tfw">
>> <Bounds>
>> <MinX>-10000000</MinX>
>> <MinY>-10000000</MinY>
>> <MaxX>10000000</MaxX>
>> <MaxY>10000000</MaxY>
>> </Bounds>
>> </Image>
>> </Band>
>> </Feature>
>> <Image frame="1" name="2146.tif">
>> <Bounds>
>> </Bounds>
>> </Image>
>> </Band>
>> </Feature>
>> I think I'm missing something basic here. Why world files are not detected?
>> If I add same data using alias, everythink works fine.
>> On Thursday 12 June 2008 17:08:18 Kenneth Skovhede, GEOGRAF A/S wrote:
>>> I don't think re-installing Maestro will help.
>>> AFAIK MapGuide needs two setups for coordinate systems, one for MapGuide
>>> and one for the WebTier.
>>> Maestro only has access to the WebTier, so everything may work fine, but
>>> you cannot see the coordinate systems.
>>> Andrew DeMerchant skrev:
>>>> Odd, since it's been working fine all along....I'm going to try
>>>> reinstalling Maestro. As for my image layer - I've managed to get it
>>>> to show up now, but it's totally crazy. If I do a layer preview in
>>>> Studio, I see a single image - should be about 6....and it's scale is
>>>> messed up, because I have to zoom way way out to see it.
>>>> Andrew
>>>>> I think you are having a problem with MapGuide's coordinate system:
>>>>> http://trac.osgeo.org/mapguide/ticket/582
>>>>>> Ah. Easy....thanks! Now when I did that, of course, my coords system
>>>>>> overrides got messed up and I can't seem to fix them from Maestro
>>>>>> (or anywhere, so far) - In Maestro, all I get in my coord category
>>>>>> list is Arbitrary X-Y....If I just paste in the correct string,
>>>>>> it'll take it - but every time I refresh my overrides, it adds a
>>>>>> Default in XY-MT. If I look at the configuration document using
>>>>>> Studio, I see that it's got some coord system stuff in it (in
>>>>>> <fdo:WKT>), and that it's wrong (it's using XY-MT). I'm guessing
>>>>>> this is the problem, but have no idea how to fix it. Here's that
>>>>>> section in the configuration doc:
>>>>>> <gml:baseCRS>
>>>>>> <fdo:WKTCRS gml:id="Default">
>>>>>> <gml:srsName>Default</gml:srsName>
>>>>>> <fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
>>>>>> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
>>>>>> </fdo:WKTCRS>
>>>>>> </gml:baseCRS>
>>>>>> <gml:definedByConversion
>>>>>> xlink:href="http://fdo.osgeo.org/coord_conversions#identity" <http://fdo.osgeo.org/coord_conversions#identity> />
>>>>>> <gml:derivedCRSType
>>>>>> codeSpace="http://fdo.osgeo.org/crs_types" <http://fdo.osgeo.org/crs_types>>geographic</gml:derivedCRSTy
>>>>>> pe> <gml:usesCS
>>>>>> xlink:href="http://fdo.osgeo.org/cs#default_cartesian" <http://fdo.osgeo.org/cs#default_cartesian> />
>>>>>> </gml:DerivedCRS>
>>>>>> Andrew
>>>>>>> Create a new GDal raster (or open an existing).
>>>>>>> In the "Type" field select "Composite".
>>>>>>> Now add files and folders in the list below.
>>>>>>>> The Gdalnotes wiki says:
>>>>>>>> "With the release of FDOGDAL 3.2.3, Frank has added support for
>>>>>>>> tile indexes in an XML config file.
>>>>>>>> MapGuide Maestro <http://trac.osgeo.org/mapguide/wiki/maestro>
>>>>>>>> will allow you to create these tile indexes in an intuitive GUI."
>>>>>>>> Where do I find that gui?
>>>>>>>> Andrew
>>>>>>>> *Andrew DeMerchant*
>>>>>>>> *Computer Technologist*
>>>>>>>> ph.1-877-2GEMTEC x.163
>>>>>>>> fax 506-453-9470
>>>>>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>>>>>> /191 Doak Road
>>>>>>>> Fredericton, NB, Canada
>>>>>>>> E3C 2E6
>>>>>>>> _______________________________________________
>>>>>>>> mapguide-users mailing list
>>>>>>>> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>> *Andrew DeMerchant*
>>>>>> fax 506-453-9470
>>>>>> /191 Doak Road
>>>>>> E3C 2E6
>>>> *Andrew DeMerchant*
>>>> fax 506-453-9470
>>>> /191 Doak Road
>>>> E3C 2E6
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080612/e86bae93/attachment.html
