[mapguide-users] image tile indexes from Maestro?
Dumas A
dumas65 at gmail.com
Thu Jun 12 13:09:19 EDT 2008
If I add alias (directory with same tiffs) to datasource, map is displayed
correctly. I tried to add geo tiff or ecw via composite mode it loses
coordinate information to. I was thinking it is problem with world files,
but it seems that it is problem in gdal, mapguide maestro or MGOS.
Any Ideas how to solve it?
P.S. I tried to add tiles data vie php script found in FDO website
(rasterconfig.php). same problem too... :(
On Thu, Jun 12, 2008 at 6:30 PM, Kenneth Skovhede, GEOGRAF A/S <
ks at geograf.dk> wrote:
> I have seen this happen when the images are not accepted by GDAL.
> For some reason it does not return an error, but rather some large values.
> What happens if you try to use a single file (ea. not composite mode)?
> Do you get the correct coordinate system?
> If not, you can try to debug with the regular raster debug guide:
> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Danas Augutis skrev:
> I'm Playing with this function to. The problem is that in XML i get wrong
> cordinates for tiff files:
> <Location name="E:\Data\ORT10LT-2006\2\">
> <Feature name="2146">
> <Band name="RGB" number="1">
> <Image frame="1" name="2146.tfw">
> <Bounds>
> <MinX>-10000000</MinX>
> <MinY>-10000000</MinY>
> <MaxX>10000000</MaxX>
> <MaxY>10000000</MaxY>
> </Bounds>
> </Image>
> </Band>
> </Feature>
> <Image frame="1" name="2146.tif">
> <Bounds>
> </Bounds>
> </Image>
> </Band>
> </Feature>
> I think I'm missing something basic here. Why world files are not detected?
> If I add same data using alias, everythink works fine.
> On Thursday 12 June 2008 17:08:18 Kenneth Skovhede, GEOGRAF A/S wrote:
> I don't think re-installing Maestro will help.
> AFAIK MapGuide needs two setups for coordinate systems, one for MapGuide
> and one for the WebTier.
> Maestro only has access to the WebTier, so everything may work fine, but
> you cannot see the coordinate systems.
> Andrew DeMerchant skrev:
> Odd, since it's been working fine all along....I'm going to try
> reinstalling Maestro. As for my image layer - I've managed to get it
> to show up now, but it's totally crazy. If I do a layer preview in
> Studio, I see a single image - should be about 6....and it's scale is
> messed up, because I have to zoom way way out to see it.
> Andrew
> I think you are having a problem with MapGuide's coordinate system:http://trac.osgeo.org/mapguide/ticket/582
> Ah. Easy....thanks! Now when I did that, of course, my coords system
> overrides got messed up and I can't seem to fix them from Maestro
> (or anywhere, so far) - In Maestro, all I get in my coord category
> list is Arbitrary X-Y....If I just paste in the correct string,
> it'll take it - but every time I refresh my overrides, it adds a
> Default in XY-MT. If I look at the configuration document using
> Studio, I see that it's got some coord system stuff in it (in
> <fdo:WKT>), and that it's wrong (it's using XY-MT). I'm guessing
> this is the problem, but have no idea how to fix it. Here's that
> section in the configuration doc:
> <gml:baseCRS>
> <fdo:WKTCRS gml:id="Default">
> <gml:srsName>Default</gml:srsName>
> <fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
> </fdo:WKTCRS>
> </gml:baseCRS>
> <gml:definedByConversion
> xlink:href="http://fdo.osgeo.org/coord_conversions#identity" <http://fdo.osgeo.org/coord_conversions#identity> />
> <gml:derivedCRSType
> codeSpace="http://fdo.osgeo.org/crs_types" <http://fdo.osgeo.org/crs_types>>geographic</gml:derivedCRSTy
> pe> <gml:usesCS
> xlink:href="http://fdo.osgeo.org/cs#default_cartesian" <http://fdo.osgeo.org/cs#default_cartesian> />
> </gml:DerivedCRS>
> Andrew
> Create a new GDal raster (or open an existing).
> In the "Type" field select "Composite".
> Now add files and folders in the list below.
> The Gdalnotes wiki says:
> "With the release of FDOGDAL 3.2.3, Frank has added support for
> tile indexes in an XML config file.
> MapGuide Maestro <http://trac.osgeo.org/mapguide/wiki/maestro> <http://trac.osgeo.org/mapguide/wiki/maestro>
> will allow you to create these tile indexes in an intuitive GUI."
> Where do I find that gui?
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca> <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080612/f8d82d91/attachment.html
