[mapguide-users] Cannot Establish Connection
Dave Wilson dave.wilson at autodesk.com
Thu Jun 12 13:22:36 EDT 2008
You might also try correlating any event log entries from the OS to get the time of the crash and look at the Access logs to see what was accessed just prior.
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark Pendergraft
Sent: Thursday, June 12, 2008 10:39 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Cannot Establish Connection
Oops.  Meant IIS 5.0
I am using .NET
For providers I am using only SDF
I will monitor the Access logs and if anything suspicious pops out at me, I will post that as well.
Again, thanks for any help provided.
-Mark P.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Thursday, June 12, 2008 9:26 AM
How did you manage to get IIS 8.0 running on Windows 2000? Are you using .NET? Microsoft changed the behavior of Applications pools at some point so that they will dump with an error where they didn't before. This could be related to your behavior. It might not be.
Use the Access logs to determine the last set of operations you were doing and try to figure out if certain data is causing problems.
Which providers are you using?
Dave
Sent: Thursday, June 12, 2008 10:21 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Cannot Establish Connection
Ever since moving to MGOS 2.0 my map keeps crashing and giving users a "Cannot Establish Connection" error.  It appears the service is actually stopping on the machine hosting the map, and I have to go in and restart it.  It happens about every other day, and sometimes several times a day.
The server running MGOS is using Windows Server 2000 sp4 and IIS 8.0
Any ideas on why this is happening?  It's really starting to get annoying, and if I can't find a fix then I will have to downgrade to 1.2.
Thanks.
-Mark P.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080612/5095b916/attachment.html
