[mapguide-users] Cannot Establish Connection
Mark Pendergraft markp at Meadgilman.com
Thu Jun 12 12:39:09 EDT 2008
Oops.  Meant IIS 5.0
I am using .NET
For providers I am using only SDF
I will monitor the Access logs and if anything suspicious pops out at
me, I will post that as well.
Again, thanks for any help provided.
-Mark P.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Thursday, June 12, 2008 9:26 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Cannot Establish Connection
How did you manage to get IIS 8.0 running on Windows 2000? Are you using
.NET? Microsoft changed the behavior of Applications pools at some point
so that they will dump with an error where they didn't before. This
could be related to your behavior. It might not be.
Use the Access logs to determine the last set of operations you were
doing and try to figure out if certain data is causing problems.
Which providers are you using?
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark
Pendergraft
Sent: Thursday, June 12, 2008 10:21 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Cannot Establish Connection
Ever since moving to MGOS 2.0 my map keeps crashing and giving users a
"Cannot Establish Connection" error.  It appears the service is actually
stopping on the machine hosting the map, and I have to go in and restart
it.  It happens about every other day, and sometimes several times a
day.
The server running MGOS is using Windows Server 2000 sp4 and IIS 8.0
Any ideas on why this is happening?  It's really starting to get
annoying, and if I can't find a fix then I will have to downgrade to
1.2.
Thanks.
-Mark P.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080612/05f0c22a/attachment.html
