[mapguide-users] Cannot Establish Connection
Dave Wilson
dave.wilson at autodesk.com
Thu Jun 12 12:26:23 EDT 2008
How did you manage to get IIS 8.0 running on Windows 2000? Are you using .NET? Microsoft changed the behavior of Applications pools at some point so that they will dump with an error where they didn't before. This could be related to your behavior. It might not be.
Use the Access logs to determine the last set of operations you were doing and try to figure out if certain data is causing problems.
Which providers are you using?
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark Pendergraft
Sent: Thursday, June 12, 2008 10:21 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Cannot Establish Connection
Ever since moving to MGOS 2.0 my map keeps crashing and giving users a "Cannot Establish Connection" error. It appears the service is actually stopping on the machine hosting the map, and I have to go in and restart it. It happens about every other day, and sometimes several times a day.
The server running MGOS is using Windows Server 2000 sp4 and IIS 8.0
Any ideas on why this is happening? It's really starting to get annoying, and if I can't find a fix then I will have to downgrade to 1.2.
Thanks.
-Mark P.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080612/ddd98012/attachment.html
