[mapguide-users] Cannot Establish Connection
Mark Pendergraft markp at Meadgilman.com
Thu Jun 12 14:07:49 EDT 2008
I don't get it????
All my code is written in .NET, so why would I use PHP?
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rock Beans
Sent: Thursday, June 12, 2008 10:42 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Cannot Establish Connection
Might as well use PHP for the viewer since it is required anyway for the
MapAdmin.
On Thu, Jun 12, 2008 at 11:39 AM, Mark Pendergraft
<markp at meadgilman.com> wrote:
Oops.  Meant IIS 5.0
I am using .NET
For providers I am using only SDF
I will monitor the Access logs and if anything suspicious pops out at
me, I will post that as well.
Again, thanks for any help provided.
-Mark P.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Thursday, June 12, 2008 9:26 AM
Subject: RE: [mapguide-users] Cannot Establish Connection
How did you manage to get IIS 8.0 running on Windows 2000? Are you using
.NET? Microsoft changed the behavior of Applications pools at some point
so that they will dump with an error where they didn't before. This
could be related to your behavior. It might not be.
Use the Access logs to determine the last set of operations you were
doing and try to figure out if certain data is causing problems.
Which providers are you using?
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark
Pendergraft
Sent: Thursday, June 12, 2008 10:21 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Cannot Establish Connection
Ever since moving to MGOS 2.0 my map keeps crashing and giving users a
"Cannot Establish Connection" error.  It appears the service is actually
stopping on the machine hosting the map, and I have to go in and restart
it.  It happens about every other day, and sometimes several times a
day.
The server running MGOS is using Windows Server 2000 sp4 and IIS 8.0
Any ideas on why this is happening?  It's really starting to get
annoying, and if I can't find a fix then I will have to downgrade to
1.2.
Thanks.
-Mark P.
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080612/ad2bcfbb/attachment.html
