[mapguide-users] Cannot Establish Connection
nclayton
nclayton at gmail.com
Thu Jun 12 14:39:13 EDT 2008
I've been dealing with this since MGOS 1.2 and continue to have the problem
in 2.0.1
In the Application Error log, i'm getting:
Faulting application mgserver.exe, version 2.0.0.2716, faulting module
msvcr80.dll, version 8.0.50727.1433, fault address 0x00008aa0.
AND
Faulting application w3wp.exe, version 6.0.3790.3959, faulting module
kernel32.dll, version 5.2.3790.4062, fault address 0x0000bee7.
Then the System Error log has:
The MapGuide Server v2.0 service terminated unexpectedly. It has done this
XX time(s).
AND
A process serving application pool 'MGOS' suffered a fatal communication
error wit the World Wide Web Publishing Service. The process id was 'XXXX'.
The data field contains the error number.
That error number is: 8007006d
A lot of the stability issues were corrected in 2.0.1 but I'm getting more
crashes now than with 2.0...I've had to change my mgos restart script from
running every 4 hours to every 1 hour and may have to reduce it further...
Mark Pendergraft wrote:
> Ever since moving to MGOS 2.0 my map keeps crashing and giving users a
> "Cannot Establish Connection" error. It appears the service is actually
> stopping on the machine hosting the map, and I have to go in and restart
> it. It happens about every other day, and sometimes several times a
> day.
> The server running MGOS is using Windows Server 2000 sp4 and IIS 8.0
> Any ideas on why this is happening? It's really starting to get
> annoying, and if I can't find a fix then I will have to downgrade to
> 1.2.
> Thanks.
> -Mark P.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Cannot-Establish-Connection-tp17803969p17806925.html
