[mapguide-users] EPSG Coordinate System to local coordinate system
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Jun 13 03:21:44 EDT 2008
As for the missing coordinate systems in Maestro, look here:
http://trac.osgeo.org/mapguide/ticket/582
Regards, Kenneth Skovhede, GEOGRAF A/S
Jamo181 skrev:
> Anyone have any good tutorials on writting the coordinate transformation
> codes used in mapguide?
> I have data in EPSG:28356 and I would like to be able to transform it to a
> local coordinate system, which basically moves scales and rotates about a
> point (?transverse mercator?). also to be a pain would this be able to be
> done dynamically, or will the map have to be exchanged for another one?
> Also I think my work computer may be blocking the EPSG codes in Maestro, my
> home PC shows the EPSG codes in the drop down however the work one doesn't
> show any, does Maestro grab these codes from a web service ? if so what
> service is it and what would need to be done to allow this? or perhaps I've
> got something set up wrong.
> On another note is it possible to rotate the map ? for displaying purposes?
> say I hav a road that runs diagonally across the screen and the user wants
> to show in horizontal, I would like to rotate the view without effecting the
> coordinates.
> Cheers in advance.
> Adam J
