[mapguide-users] Join features
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Jun 13 06:00:27 EDT 2008
AFAIK, webstudio does not support this.
Maestro does:
http://trac.osgeo.org/mapguide/wiki/maestro
If you have access to Autodesk MapGuide Studio, it does as well.
To add it through the API, you must edit the Xml for the FeatureSource.
I have seen no documentation for this.
I would recomend you set up a Join using Maestro/Studio and look at the
generated Xml to figure out how it works.
Regards, Kenneth Skovhede, GEOGRAF A/S
mulel skrev:
> Hi all,
> Is it possible to join two features using webstudio? If not, is it possible
> to do the features join using the mapguide API? Any example?
> Thanks in advance.
> Manel
