[mapguide-users] Join features
Manel Gimeno manelgimeno at gmail.com
Fri Jun 13 06:16:21 EDT 2008
Thanks a lot Kenneth.
I will try it this weekend. If I have any problem I hope you will help me ;-)
Regards
Manel
softimiza
Mestre Miró, 28
08211 Castellar del Vallès
Barcelona - Spain
www.softimiza.com
Manel Gimeno
Director Gerente / CEO · R&D
Mobile:  +34 671 039 214
Tel:        +34 931 143 187
Fax:       +34 931 143 227
e-mail:   mgimeno at softimiza.com
  ----- Original Message -----
  To: MapGuide Users Mail List
  Sent: Friday, June 13, 2008 12:00 PM
  Subject: Re: [mapguide-users] Join features
  AFAIK, webstudio does not support this.
  Maestro does:
  http://trac.osgeo.org/mapguide/wiki/maestro
  If you have access to Autodesk MapGuide Studio, it does as well.
  To add it through the API, you must edit the Xml for the FeatureSource.
  I have seen no documentation for this.
  I would recomend you set up a Join using Maestro/Studio and look at the
  generated Xml to figure out how it works.
  Regards, Kenneth Skovhede, GEOGRAF A/S
  mulel skrev:
  > Hi all,
  > Is it possible to join two features using webstudio? If not, is it possible
  > to do the features join using the mapguide API? Any example?
  > Thanks in advance.
  > Manel
  mapguide-users mailing list
  mapguide-users at lists.osgeo.org
  http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080613/c5d32723/attachment.html
