[mapguide-users] Limitation on the Number of Labeling
Dave Wilson
dave.wilson at autodesk.com
Fri Jun 13 10:41:12 EDT 2008
It sounds like the draw order of your new POI layer is not above the interstate layer in your map.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Theresazhxp
Sent: Friday, June 13, 2008 1:37 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Limitation on the Number of Labeling
I'm creating an raster image by sending a GetMap request to MapGuide Server.
Currently I met a labeling issue. The map has several layers, and one of
them is interstate freeway. It's labeled by its Number. Around New York area
there are a lot of interstate, so there are a lot of labels on the map.
Meanwhile I create another layer dynamically in my codes to show my POI. I
also label the POIs. When I get an image around New York, interstate has
labels, but my POI has no label, even if I set the POI label fixed through
MapGuide Studio. When I turn off the interstate label, my POI labels show
correctly. So I guess too many interstate labels cause MapGuide Server not
show the POI labels.
Any ideas?
Thanks!
View this message in context: http://www.nabble.com/Limitation-on-the-Number-of-Labeling-tp17816868p17816868.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
