[mapguide-users] Limitation on the Number of Labeling
Traian Stanev traian.stanev at autodesk.com
Fri Jun 13 11:27:39 EDT 2008
Try switching the draw order of the two layers. This way the POI labels would get processed before the highway labels and reserve a spot on the screen early.
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Theresazhxp
> Sent: Friday, June 13, 2008 3:37 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Limitation on the Number of Labeling
> I'm creating an raster image by sending a GetMap request to MapGuide
> Server.
> Currently I met a labeling issue. The map has several layers, and one
> of
> them is interstate freeway. It's labeled by its Number. Around New York
> area
> there are a lot of interstate, so there are a lot of labels on the map.
> Meanwhile I create another layer dynamically in my codes to show my
> POI. I
> also label the POIs. When I get an image around New York, interstate
> has
> labels, but my POI has no label, even if I set the POI label fixed
> through
> MapGuide Studio. When I turn off the interstate label, my POI labels
> show
> correctly. So I guess too many interstate labels cause MapGuide Server
> not
> show the POI labels.
> Any ideas?
> Thanks!
> View this message in context: http://www.nabble.com/Limitation-on-the-
> Number-of-Labeling-tp17816868p17816868.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
