[mapguide-users] Limitation on the Number of Labeling
Theresazhxp tzheng at wernergl.com
Sun Jun 15 22:23:58 EDT 2008
Traian,
Thank you for your suggestion. It works.
Now my POI labels show up, but the highway labels disappear. Since both
labels are important, I'd like my map show both. I had thought there should
be a setting value which limits the number of the labels in MapGuide Server.
Thanks
Traian Stanev wrote:
> Try switching the draw order of the two layers. This way the POI labels
> would get processed before the highway labels and reserve a spot on the
> screen early.
> Traian
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>> bounces at lists.osgeo.org] On Behalf Of Theresazhxp
>> Sent: Friday, June 13, 2008 3:37 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] Limitation on the Number of Labeling
>> I'm creating an raster image by sending a GetMap request to MapGuide
>> Server.
>> Currently I met a labeling issue. The map has several layers, and one
>> of
>> them is interstate freeway. It's labeled by its Number. Around New York
>> area
>> there are a lot of interstate, so there are a lot of labels on the map.
>> Meanwhile I create another layer dynamically in my codes to show my
>> POI. I
>> also label the POIs. When I get an image around New York, interstate
>> has
>> labels, but my POI has no label, even if I set the POI label fixed
>> through
>> MapGuide Studio. When I turn off the interstate label, my POI labels
>> show
>> correctly. So I guess too many interstate labels cause MapGuide Server
>> not
>> show the POI labels.
>> Any ideas?
>> Thanks!
>> View this message in context: http://www.nabble.com/Limitation-on-the-
>> Number-of-Labeling-tp17816868p17816868.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Limitation-on-the-Number-of-Labeling-tp17816868p17856832.html
