[mapguide-users] Mapguide Maestro and OGR FDO provider
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Jun 17 03:31:54 EDT 2008
I think what you mean is: "Joins do not work with FDO data".
If so, I have never gotten any data joined with FDO data, and I have no
clue why.
You can try to search the bug database, and add an entry if you do not
find one already.
You can use FDO2FDO to convert data to SDF and then your joins will work.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jamo181 skrev:
> Thanks Frank I'll keep this in mind down the track.
> At the moment data can be exported to shp files which can be used with
> mapguide :)
> or we can use the DGN direct through the DGN V7 OGR plugin for FDO, as our
> data is all kept in a database and isn't stored in the DGN V8 XML format,
> just means I have to save our data files to older versions prior to using
> them in mapguide no biggie, I think I can wait and see where Bentley go next
> as we seem to have all bases covered at the moment.
> One thing though, I'm able to see the geometry and select it and retrieve
> the information attached to it, however when I create a new dataconnection
> to our SQL database and Join these through a Data extension on this feature,
> It then returns no geometry .... ? any ideas?
> or better yet is there anything I can post here to give a better Idea of
> what I mean :confused:
