[mapguide-users] Mapguide Maestro and OGR FDO provider
Jamo181
adam.jamison at portbris.com.au
Mon Jun 16 20:02:14 EDT 2008
Thanks Frank I'll keep this in mind down the track.
At the moment data can be exported to shp files which can be used with
mapguide :)
or we can use the DGN direct through the DGN V7 OGR plugin for FDO, as our
data is all kept in a database and isn't stored in the DGN V8 XML format,
just means I have to save our data files to older versions prior to using
them in mapguide no biggie, I think I can wait and see where Bentley go next
as we seem to have all bases covered at the moment.
One thing though, I'm able to see the geometry and select it and retrieve
the information attached to it, however when I create a new dataconnection
to our SQL database and Join these through a Data extension on this feature,
It then returns no geometry .... ? any ideas?
or better yet is there anything I can post here to give a better Idea of
what I mean :confused:
View this message in context: http://www.nabble.com/Mapguide-Maestro-and-OGR-FDO-provider-tp17770386p17875679.html
