[mapguide-users] Theme functionality of PHPSAMPLES
erictsn at cadbeyond.com erictsn at cadbeyond.com
Tue Jun 17 04:10:54 EDT 2008
Hi All
This is the example application, is deployed "$webLayout=
"Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout";. It works
fine with the theme functionality. I tried to change the library. It work
fail! It prompts the following error:
Error
The specified class was not found.
The specified class was not found. Exception occurred in method
MgServerDescribeSchema.GetClassDefinition at line 1403 in file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
I try to check all file, can't to find this path
"d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev...".
Anyone knows how to fix?
Regards,
Eric
