[mapguide-users] CPP Build failure on Ubuntu 8.04
gimbrogno at smartlab
magnitudo9 at email.it
Wed Jun 18 09:36:19 EDT 2008
Hi, try to edit the Makefiles erasing all the -Wxxx paramethers! They are
used only to enable warnings and, the cause may be this... Try also to
downgrade the gcc compiler version, infact the 4.2.3 bundled with ububtu
8.04 causes some errors... Regards
SD-20 wrote:
> Background:
> - went through normal install steps at
> http://mapguide.osgeo.org/2.0/docs/BuildInstallQuickStartLinux.html
> - using files from
> http://download.osgeo.org/mapguide/releases/2.0.1/mapguide-2.0.1.2716.tar.gz
> Everything works until running ./build_oem.sh where this error occurs:
> /bin/sh ./libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I..
> -g0 -O2 -pipe -Wall -Wno-long-long -Wnon-virtual-dtor -Wsign-promo
> -Wsign-compare -Wundef -Wstrict-prototypes -fforce-addr
> -finline-functions -ffast-math -fno-strict-aliasing -MT
> BufferOutputStream.lo -MD -MP -MF .deps/BufferOutputStream.Tpo -c -o
> BufferOutputStream.lo BufferOutputStream.cpp
> g++ -DHAVE_CONFIG_H -I.. -g0 -O2 -pipe -Wall -Wno-long-long
> -Wnon-virtual-dtor -Wsign-promo -Wsign-compare -Wundef
> -Wstrict-prototypes -fforce-addr -finline-functions -ffast-math
> -fno-strict-aliasing -MT BufferOutputStream.lo -MD -MP -MF
> .deps/BufferOutputStream.Tpo -c BufferOutputStream.cpp -fPIC -DPIC -o
> .libs/BufferOutputStream.o
> cc1plus: warning: command line option "-Wstrict-prototypes" is valid
> for Ada/C/ObjC but not for C++
> BufferOutputStream.cpp: In member function 'virtual size_t
> DWFCore::DWFBufferOutputStream::write(const void*, size_t)':
> BufferOutputStream.cpp:192: error: expected primary-expression before '?'
> token
> BufferOutputStream.cpp:192: error: expected `:' before ';' token
> BufferOutputStream.cpp:192: error: expected primary-expression before ';'
> token
> make[2]: *** [BufferOutputStream.lo] Error 1
> make[2]: Leaving directory
> `/opt/install/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> make: *** [all] Error 2
> DWFCORE 1.0: Error build failed (0).................
> I thought maybe the BufferOutputStream.cpp was corrupted, so compared
> it with version at
> http://svn.osgeo.org/mapguide/trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/BufferOutputStream.cpp
> which was identical.
> There is a '?' in the file, but it is on line 110, not 192.
> Anyone know what I'm doing wrong? :-)
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/CPP-Build-failure-on-Ubuntu-8.04-tp17876969p17982853.html
