[mapguide-users] Vehicle Tracking
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Jun 17 05:58:31 EDT 2008
So you want to display only the most recent vehicle positions?
You can do that with a filter on the layer.
I suspect you have a datastructure like:
x double
y double
vehicleid integer
timestamp datetime
You should have a filter like: "timestamp = (select top 1 timestamp from
table where vehicleid = id)".
How this filter should look, depends on your database.
I suspect you will have a hard time figuring this out (if it is even
possible) directly in MapGuide.
I would advise you to add a column that indicates that this is the most
recent entry:
mostrecent integer
then you can update the database upon arival of requests:
update table set mostrecent = 0 where vehicleid=id
and insert
insert into table (x,y,vehicleid,timestamp,mostrecent) values
(x,y,id,now(),1)
This will allow you to have a filter like this in your layer:
"mostrecent = 1"
Regards, Kenneth Skovhede, GEOGRAF A/S
Vishaal skrev:
> Hi Kenneth,
> i am successful in displaying the points on a button click all at once. what
> i want is that on the button click my points should get displayed one by one
> as per the data and only the latest point should be visible. i am not able
> to this part. can you help me with some code example?
> thanks.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> If you only have to consider the current position of vehicles, you can
>> easily use a database.
>> Just add an x,y columns, and perhaps speed and other data to a table.
>> Then make a service that accepts coordinates from vehicles, and update
>> the correct row in the database.
>> In MapGuide, make a layer that reads the x,y points, and perhaps color
>> code according to speed.
>> You can then get away with refreshing the map periodically.
>> If you can read in the direction, you could throw in a rotation on a
>> symbol in the layer.
>> Vishaal skrev:
>>> Hi List,
>>> i want to develop a vehicle tracking system using MGOS 1.2 and Visual
>>> Studio
>>> 2005. if any one can guide me about how to start for the application,
>>> then
>>> it will be very helpful to me. thanks for all your support.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080617/bf5aafab/attachment.html
