[mapguide-users] Vehicle Tracking
Pierre Gauthier
pierrega at consortech.com
Tue Jun 17 08:31:49 EDT 2008
Hi!
Another suggestion would be to use two tables. One for "latest" known
position and one for "historical" position.
When you receive vehicle information, you update the "latest" table (or
insert if it is the first entry for a given vehicle) and you insert into
the "historical" one. Thus, if you want to display the current vehicle
position, you don't have to bother about filtering, you have all what
you need, one row per vehicle, in the "latest" table. On the other
hand, when you want to playback a vehicle route for let's say the
previous day, you can use the "historical" table.
Pierre
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: June 17, 2008 05:59
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Vehicle Tracking
So you want to display only the most recent vehicle positions?
You can do that with a filter on the layer.
I suspect you have a datastructure like:
x double
y double
vehicleid integer
timestamp datetime
You should have a filter like: "timestamp = (select top 1 timestamp from
table where vehicleid = id)".
How this filter should look, depends on your database.
I suspect you will have a hard time figuring this out (if it is even
possible) directly in MapGuide.
I would advise you to add a column that indicates that this is the most
recent entry:
mostrecent integer
then you can update the database upon arival of requests:
update table set mostrecent = 0 where vehicleid=id
and insert
insert into table (x,y,vehicleid,timestamp,mostrecent) values
(x,y,id,now(),1)
This will allow you to have a filter like this in your layer:
"mostrecent = 1"
Regards, Kenneth Skovhede, GEOGRAF A/S
Vishaal skrev:
Hi Kenneth,
i am successful in displaying the points on a button click all at once.
what
i want is that on the button click my points should get displayed one by
one
as per the data and only the latest point should be visible. i am not
able
to this part. can you help me with some code example?
thanks.
Kenneth Skovhede, GEOGRAF A/S wrote:
If you only have to consider the current position of vehicles,
you can
easily use a database.
Just add an x,y columns, and perhaps speed and other data to a
table.
Then make a service that accepts coordinates from vehicles, and
update
the correct row in the database.
In MapGuide, make a layer that reads the x,y points, and perhaps
color
code according to speed.
You can then get away with refreshing the map periodically.
If you can read in the direction, you could throw in a rotation
on a
symbol in the layer.
Vishaal skrev:
Hi List,
i want to develop a vehicle tracking system using MGOS
1.2 and Visual
Studio
2005. if any one can guide me about how to start for the
application,
then
it will be very helpful to me. thanks for all your
support.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080617/2d3aee9f/attachment.html
