[mapguide-users] Java and Linux
gimbrogno at smartlab magnitudo9 at email.it
Wed Jun 18 02:50:36 EDT 2008
Hi all, thanks for your answers...
First I try the version 2.0.1 of MapGuide, but it doesn't run with jsp
pages, so I would to try the previous version.
I didn't specify the LD_LIBRARY_PATH during the configure step, but it
considers the fdo-3.2.3.
Do you think that I must re-compile the suite specifing the path of fdo
libraries?
Regards, Gianfranco
gimbrogno @smartlab wrote:
> Hi all,
> excuse me for my continuos requests, but I'm still trying to solve my
> problems with MapGuide on Linux and Java example.
> I'll try to describe all steps I've covered, just to be sure I'm not
> leaving anything behind and doing nothing wrong.
> I've compiled and tryied both the 2.0.1 and 1.2 releases without success,
> it's going to get frustrating as all my day is spent compiling and trying
> to figure out what's wrong, while I can read on this list you all have the
> things up and running smoothly... please, help me exit the tunnel! :-P
> Well, what I've done is compile the entire MapGuide project with some
> modifications to Makefiles as they were not working (missing libraries,
> wrong gcc as the one I was using didn't support march-i386 and stuff like
> this) on my Centos 5 server.
> I've managed to compile the entire suite and I'm actually able to use the
> PHP ajax viewer example without any problem, but when it comes to Java
> viewer I'm facing some strange linkage errors regarding a missing
> SWIGMgSerializableToMgGuardDisposable native function.
> I've gone deeper on the problem and I finally understood the Java API is
> practically generated through SWIG from C++ code and I'm wondering if that
> generation process could have produced any nonworking code.
> So, my qyestions are:
>  - should I regenerate the java api through SWIG to be sure the code was
> generated correctly?
>  - should I try to generate the java library using the latest version of
> SWIG?
>  - should I tell my boss we can't use the java library at all?
>  - in case the first two questions get a positive answer can someone help
> me pointing to some documentation for the generation process regarding the
> MapGuide code (which sources should I use as input and stuff like that)?
> Thank you all guys!
View this message in context: http://www.nabble.com/Java-and-Linux-tp17916025p17960791.html
