[mapguide-users] Java and Linux
gimbrogno at smartlab
magnitudo9 at email.it
Fri Jun 20 09:16:06 EDT 2008
Hi all, mapguide runs jsp pages!!!
When I click on http://server:8080/mapguide/mapviewerjava/bufferui.jsp it
goes!
But when I try to launch jvaviewersample.jsp, the server launch an
exception:
exception
org.apache.jasper.JasperException: javax.servlet.ServletException:
java.lang.NoClassDefFoundError
root cause
javax.servlet.ServletException: java.lang.NoClassDefFoundError
... where is the problem? Help me please...
Rock Beans wrote:
> Also keep in mind that MapGuide requires PHP anyway for the MapAdmin so it
> might be easier to work with PHP to ease implementations.
> The Rock
> On Wed, Jun 18, 2008 at 10:05 AM, gimbrogno @smartlab
> <magnitudo9 at email.it>
> wrote:
>> Hi, new re-compile of mapguide 1.2.0...
>> After the command "make install" I could see some of these texts:
>> Libraries have been installed in:
>> /usr/local/mapguideopensource/webserverextensions/lib
>> If you ever happen to want to link against installed libraries
>> in a given directory, LIBDIR, you must either use libtool, and
>> specify the full pathname of the library, or use the `-LLIBDIR'
>> flag during linking and do at least one of the following:
>> - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
>> during execution
>> - add LIBDIR to the `LD_RUN_PATH' environment variable
>> during linking
>> - use the `-Wl,--rpath -Wl,LIBDIR' linker flag
>> - have your system administrator add LIBDIR to `/etc/ld.so.conf'
>> See any operating system documentation about shared libraries for
>> more information, such as the ld(1) and ld.so(8) manual pages.
>> I edited /etc/ld.so.conf, and I added the directory where the share
>> libraries are installed but I have not had success with jsp pages :(
>> Can anyone helps me?
>> Thanks
>> gimbrogno @smartlab wrote:
>> > Hi all, thanks for your answers...
>> > First I try the version 2.0.1 of MapGuide, but it doesn't run with jsp
>> > pages, so I would to try the previous version.
>> > I didn't specify the LD_LIBRARY_PATH during the configure step, but it
>> > considers the fdo-3.2.3.
>> > Do you think that I must re-compile the suite specifing the path of fdo
>> > libraries?
>> > Regards, Gianfranco
>> >> Hi all,
>> >> excuse me for my continuos requests, but I'm still trying to solve my
>> >> problems with MapGuide on Linux and Java example.
>> >> I'll try to describe all steps I've covered, just to be sure I'm not
>> >> leaving anything behind and doing nothing wrong.
>> >> I've compiled and tryied both the 2.0.1 and 1.2 releases without
>> success,
>> >> it's going to get frustrating as all my day is spent compiling and
>> trying
>> >> to figure out what's wrong, while I can read on this list you all have
>> >> the things up and running smoothly... please, help me exit the tunnel!
>> >> :-P
>> >> Well, what I've done is compile the entire MapGuide project with some
>> >> modifications to Makefiles as they were not working (missing
>> libraries,
>> >> wrong gcc as the one I was using didn't support march-i386 and stuff
>> like
>> >> this) on my Centos 5 server.
>> >> I've managed to compile the entire suite and I'm actually able to use
>> the
>> >> PHP ajax viewer example without any problem, but when it comes to Java
>> >> viewer I'm facing some strange linkage errors regarding a missing
>> >> SWIGMgSerializableToMgGuardDisposable native function.
>> >> I've gone deeper on the problem and I finally understood the Java API
>> is
>> >> practically generated through SWIG from C++ code and I'm wondering if
>> >> that generation process could have produced any nonworking code.
>> >> So, my qyestions are:
>> >> - should I regenerate the java api through SWIG to be sure the code
>> was
>> >> generated correctly?
>> >> - should I try to generate the java library using the latest version
>> of
>> >> SWIG?
>> >> - should I tell my boss we can't use the java library at all?
>> >> - in case the first two questions get a positive answer can someone
>> help
>> >> me pointing to some documentation for the generation process regarding
>> >> the MapGuide code (which sources should I use as input and stuff like
>> >> that)?
>> >> Thank you all guys!
>> View this message in context:
>> http://www.nabble.com/Java-and-Linux-tp17916025p17984721.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Java-and-Linux-tp17916025p18029347.html
