[mapguide-users] Java and Linux
Rock Beans rockbeans at gmail.com
Wed Jun 18 14:46:44 EDT 2008
Also keep in mind that MapGuide requires PHP anyway for the MapAdmin so it
might be easier to work with PHP to ease implementations.
The Rock
On Wed, Jun 18, 2008 at 10:05 AM, gimbrogno @smartlab <magnitudo9 at email.it>
wrote:
> Hi,  new re-compile of mapguide 1.2.0...
> After the command "make install" I could see some of these texts:
> Libraries have been installed in:
>   /usr/local/mapguideopensource/webserverextensions/lib
> If you ever happen to want to link against installed libraries
> in a given directory, LIBDIR, you must either use libtool, and
> specify the full pathname of the library, or use the `-LLIBDIR'
> flag during linking and do at least one of the following:
>   - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
>     during execution
>   - add LIBDIR to the `LD_RUN_PATH' environment variable
>     during linking
>   - use the `-Wl,--rpath -Wl,LIBDIR' linker flag
>   - have your system administrator add LIBDIR to `/etc/ld.so.conf'
> See any operating system documentation about shared libraries for
> more information, such as the ld(1) and ld.so(8) manual pages.
> I edited /etc/ld.so.conf, and I added the directory where the share
> libraries are installed but I have not had success with jsp pages :(
> Can anyone helps me?
> Thanks
> gimbrogno @smartlab wrote:
> > Hi all, thanks for your answers...
> > First I try the version 2.0.1 of MapGuide, but it doesn't run with jsp
> > pages, so I would to try the previous version.
> > I didn't specify the LD_LIBRARY_PATH during the configure step, but it
> > considers the fdo-3.2.3.
> > Do you think that I must re-compile the suite specifing the path of fdo
> > libraries?
> > Regards, Gianfranco
> >> Hi all,
> >> excuse me for my continuos requests, but I'm still trying to solve my
> >> problems with MapGuide on Linux and Java example.
> >> I'll try to describe all steps I've covered, just to be sure I'm not
> >> leaving anything behind and doing nothing wrong.
> >> I've compiled and tryied both the 2.0.1 and 1.2 releases without
> success,
> >> it's going to get frustrating as all my day is spent compiling and
> trying
> >> to figure out what's wrong, while I can read on this list you all have
> >> the things up and running smoothly... please, help me exit the tunnel!
> >> :-P
> >> Well, what I've done is compile the entire MapGuide project with some
> >> modifications to Makefiles as they were not working (missing libraries,
> >> wrong gcc as the one I was using didn't support march-i386 and stuff
> like
> >> this) on my Centos 5 server.
> >> I've managed to compile the entire suite and I'm actually able to use
> the
> >> PHP ajax viewer example without any problem, but when it comes to Java
> >> viewer I'm facing some strange linkage errors regarding a missing
> >> SWIGMgSerializableToMgGuardDisposable native function.
> >> I've gone deeper on the problem and I finally understood the Java API is
> >> practically generated through SWIG from C++ code and I'm wondering if
> >> that generation process could have produced any nonworking code.
> >> So, my qyestions are:
> >>  - should I regenerate the java api through SWIG to be sure the code was
> >> generated correctly?
> >>  - should I try to generate the java library using the latest version of
> >> SWIG?
> >>  - should I tell my boss we can't use the java library at all?
> >>  - in case the first two questions get a positive answer can someone
> help
> >> me pointing to some documentation for the generation process regarding
> >> the MapGuide code (which sources should I use as input and stuff like
> >> that)?
> >> Thank you all guys!
> http://www.nabble.com/Java-and-Linux-tp17916025p17984721.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080618/1070f92a/attachment.html
