[mapguide-users] no MapGuideJavaApi in java.library.path
gimbrogno at smartlab
magnitudo9 at email.it
Fri Jun 20 10:17:01 EDT 2008
Hi all, I have not yet solved the problem with java!
Could you tell me how to set up the variable JAVA_HOME and all others?
Thank you for all suggestions
Gianfranco
Rock Beans wrote:
> Why make your life complicated? It's "Summertime" enjoy. By the time you
> get
> it working 85% stable on Linux a new version will be out and you will be
> recompiling again. I have had luck on CentOS 4 and 5. Make sure you
> JAVA_HOME and other Java variables are set. That set environment script is
> annoying but very important to the compilation process. I wish they would
> drop Java and make PHP modules to make life easier on both platforms. No
> one
> really wants to run Tomcat if they don't have to.
> Good luck,
> The Rock
> On Thu, Jun 12, 2008 at 2:34 AM, gimbrogno @smartlab <magnitudo9 at email.it>
> wrote:
>> Hi, I have installed Mapguide OpenSource on same linux systems (ubuntu
>> 7.10
>> and CentOS 5.1), but I have an error when try the java sample !!!
>> When LinuxApt is compiled, it is not able to create the MapGuideApi.jar,
>> so
>> I have copied this jar from a windows in /WEB-INF/lib.
>> Unber the directory tomcat/conf there is not Catalina/localhost, so I
>> have
>> created this two directories and I've copied the LinuxApt/mapguide.xml
>> into.
>> After these works the result page is "no MapGuideJavaApi in
>> java.library.path... ", but MapGuideJavaApi is not a jar file but a
>> static
>> object (MapGuideJavaApi.so.0.7). Where is the library path where this
>> object
>> must be copied to?
>> Under windows systems, I have no problems!!! There is anyone that uses
>> MaGuide OpenSource under Linux that can helps me?
>> Thanks in advantage... (I'm sorry for my english, but english is not my
>> native language)
>> View this message in context:
>> http://www.nabble.com/no-MapGuideJavaApi-in-java.library.path-tp17794185p17794185.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/no-MapGuideJavaApi-in-java.library.path-tp17794185p18030492.html
