[mapguide-users] Error connecting Postgis MapGuide Maestro ver
1.0.7.40948
Jack Lee
jack.lee at autodesk.com
Sat Jun 21 08:31:34 EDT 2008
You can ignore DWMAPI.DLL. Also, dependency walker does not show if MSVCR80.dll is actually installed. It probably is installed because if it wasn't, you would probably get other errors.
However, it won't hurt to re-installed the runtime. You need to install Microsoft Visual C++ 2005 SP1 Redistributable Package (x86)<http://www.microsoft.com/downloads/info.aspx?na=47&p=2&SrcDisplayLang=en&SrcCategoryId=&SrcFamilyId=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&u=details.aspx%3ffamilyid%3d200B2FD9-AE1A-4A14-984D-389C36F85647%26displaylang%3den>.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Saturday, June 21, 2008 6:49 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Error connecting Postgis MapGuide Maestro ver 1.0.7.40948
Libpq is the PostGreSQL connection Dll, I am not sure how you get it without installing PostGreSQL on your machine.
You can check the site: http://www.postgresql.org/ftp/
MSVCR80.dll is the Microsoft Visual C runtime:
http://www.microsoft.com/downloads/details.aspx?familyid=9B2DA534-3E03-4391-8A4D-074B9F2BC1BF&displaylang=en
I think DWMAPI.dll is in th Visual C runtime also.
Regards, Kenneth Skovhede, GEOGRAF A/S
Intengu Technologies skrev:
Dependency Walker says the system cannot find the following files LIBPQ.DLL, MSVCR80.DLL, DWMAPI.DLL
Where do I get these files and where must I put them on my system.
2008/6/20 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk<mailto:ks at geograf.dk>>:
It sounds like a required Dll is missing.
Try using Dependency Walker:
http://www.dependencywalker.com
With Depency Walker, open the file:
C:\Program Files\MapGuideOpenSource2.0\Server\Bin\FDO\PostGISProvider.dll
It should tell you what dll's are missing.
I am getting the following error -
The remote server returned an error: (559) MgFdoException.: An exception occurred in FDO component. Unable to load the FDO Provider: The specified module could not be found. Exception occurred in method MgFdoConnectionManager.Open at line 262 in file d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\common\manager\FdoConnectionManager.cpp
System: Windows XP with MGOS ver 2.0.1.2716 with Postgis 1.3.3.1<http://1.3.3.1>
Sindile Bidla
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Sindile Bidla
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080621/ba004064/attachment.html
