[mapguide-users] Mapguide Server / Worker process killer
    Kenneth Skovhede, GEOGRAF A/S
    ks at geograf.dk
    Sun Jun 22 06:17:48 EDT 2008
I don't know if Autodesk prefers that you submit bug reports directly to
them,
but for MGOS, the correct place to report errors is:
http://trac.osgeo.org/mapguide/
Since MGE/MGOS share codebase, I assume that it is easier to track the
changes on the above url.
Regards, Kenneth Skovhede, GEOGRAF A/S
Darrin Maidlow skrev:
> Hi List,
> I've found a server killing item.  I'm in the process of adding some
> layers to a runtime map object.  As a result of bug on my end, I was
> able to take out the mapguide server.  If you add a layer that
> references a layer group  to a map, but forget to first add the layer
> group to the group collection, the mapguide server fails.
> My server is MGE 2009, running on windows 2003\ IIS6.  I've replicated
> this using web tier on both 2003/IIS6 and Vista x64/IIS7
> Please let me know if this is the wrong place for reporting things
> like this.
> darrin
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080622/d1987928/attachment.html
