[mapguide-users] Mapguide Server / Worker process killer
Darrin Maidlow dmaidlow at landorgis.com
Sun Jun 22 20:45:47 EDT 2008
Thanks Kenneth,
Is it appropriate to run things such as this one through the list first?  Or
just submit them to trac?
Thanks
darrin
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: Sunday, June 22, 2008 4:18 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Mapguide Server / Worker process killer
I don't know if Autodesk prefers that you submit bug reports directly to
them,
but for MGOS, the correct place to report errors is:
http://trac.osgeo.org/mapguide/
Since MGE/MGOS share codebase, I assume that it is easier to track the
changes on the above url.
Regards, Kenneth Skovhede, GEOGRAF A/S
Darrin Maidlow skrev:
Hi List,
I've found a server killing item.  I'm in the process of adding some layers
to a runtime map object.  As a result of bug on my end, I was able to take
out the mapguide server.  If you add a layer that references a layer group
to a map, but forget to first add the layer group to the group collection,
the mapguide server fails.
My server is MGE 2009, running on windows 2003\ IIS6.  I've replicated this
using web tier on both 2003/IIS6 and Vista x64/IIS7
Please let me know if this is the wrong place for reporting things like
this.
darrin
  _____
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080622/fed826fb/attachment.html
